swooshdave
Jul 13 2014, 06:48 PM
Low beams don't work. High beams do.
Swapped relay (it's new) with another new one with no change.
Stalk has been changed at some point.
Where should I look next? At the stalk? A fuse? Somewhere else I can check for power?
zambezi
Jul 13 2014, 08:37 PM
Yes fuses. There are individual fuses for each high/low and left/right (4 fuses total). Your feet can sometimes bump the fuse panel when you get out of the car and knock some fuses loose.
Mike Bellis
Jul 13 2014, 09:09 PM
You should hear the hi/lo relay click when pulling the turn stalk. Yes/no?
swooshdave
Jul 13 2014, 09:20 PM
I looked at the fuses and they didn't look askew or shorted. I would think it would be pretty unusual to bump just the low beams.
I can check for power at the fuses.
bdstone914
Had a similar problem. Could hear the Hi low relay click but no Hi beams. Cleaned the points in the relay by dragging a piece of paper between them.
Bruce
