Has anyone snuck a 215/60R15 into a narrow 914?, Thinking about P6000s |
horizontally-opposed |
Jul 16 2014, 06:07 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
Porsche lists the 215/60R15 as an N1 tire approved for 914-6, and I am considering them as they solve the too-small diameter problem I want to avoid. Currently, I'm on 195/65s. I used to run 205/55s and 205/60s, but all of these are too small in diameter.
I know the cars vary, but I was able to run various 205/55s with no rubbing and 205/60 Yoko A008Rs years ago with only a bit of rubbing on the inside (too much negative camber at that time). I'd be running these on 15x6 911 wheels, but may pop to have them turned into 15x7Rs by Weidman and do custom spacers. Big thing is to get a summer performance tire in there with, well, performance—and the right look. That period look with any kind of performance is getting tough to find. If anyone has 215/60s on a narrow car, and can provide pics, I'd be very thankful! (IMG:style_emoticons/default/beerchug.gif) pete |
Feb 11 2016, 08:25 PM
Okay, so there was hope, or at least a little. The tire would physically fit inside the well, but there wasn't much room.
Next step was to try to locate it perfectly in there on a wheel—and I knew a 15x6 was both too narrow for a 215mm tire and unlikely to place it where it needed to be. So I borrowed a 911R wheel from a friend, which adds an inch to the inside and allows you to space the wheel as you need to. If you want to fit maximum tire under the back of a narrow 914, these are the best factory wheels for that purpose. I used washers instead of spacers to keep things easy—knowing I could have custom spacers made later if things looked good. So, here goes... Attached thumbnail(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 06:43 AM |
