Floor panel deflectors, cooling |
cpavlenko |
Jul 16 2014, 06:36 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
Sooooooo, my early 71 914 doesn't have floor panel deflectors. Will it help with cooling, and how do you put them on. I do know they were stock on 73 on 914s, Curious. (IMG:style_emoticons/default/idea.gif)
Jul 16 2014, 06:40 PM
Sooooooo, my early 71 914 doesn't have floor panel deflectors. Will it help with cooling, and how do you put them on. I do know they were stock on 73 on 914s, Curious. (IMG:style_emoticons/default/idea.gif) Yes, they will help. They are screwed to metal tabs on the lower edge of the firewall. There is at least one thread here that shows the exact placement of those, which is critical for full cooling. (IMG:style_emoticons/default/smile.gif) |
cpavlenko |
Jul 16 2014, 06:44 PM
How go I go about getting thread?
Jul 16 2014, 07:38 PM
I have a set for sale. $50 shipped. Email mark@markepstein.net if you'd like to buy.
Jul 16 2014, 08:50 PM
How go I go about getting thread? Search? (IMG:style_emoticons/default/confused24.gif) I believe Dave Darling was posting in that thread ... (IMG:style_emoticons/default/idea.gif) |
Jul 16 2014, 08:56 PM
How go I go about getting thread? Search? (IMG:style_emoticons/default/confused24.gif) I believe Dave Darling was posting in that thread ... (IMG:style_emoticons/default/idea.gif) Found this: http://www.914world.com/bbs2/index.php?s=&...t&p=1617405 Also note that they mount "backwards" with the curvature going against the air flow to maximize turbulence. (IMG:style_emoticons/default/sunglasses.gif) |
cpavlenko |
Jul 16 2014, 08:59 PM
Thanks SirAndy, much appreciated.
Elliot Cannon |
Jul 17 2014, 01:11 AM
PM bdstone. He's probably got some for ya.
edwin |
Jul 17 2014, 02:27 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
I've been thinking about this recently.
What would running a deeper section of stiff rubber across the full width and back along the sides a little do for cooling? Mainly because I'm in Australia so shipping on these would be relatively painful. Cheers Edwin |
Jul 17 2014, 11:28 AM
What would running a deeper section of stiff rubber across the full width and back along the sides a little do for cooling? That might not be as efficient. They are placed to specifically aid the air flow where the air comes down from the cylinders. When you look at the underside with the car on the lift, you can see that Porsche was aiming for those two spots in particular to help with moving the hot air away from under the cylinders. A lip over the full width might actually hinder cooling ... (IMG:style_emoticons/default/idea.gif) PS: Are you running a rear valance? That will trap hot air. Also, unless you go over 100mph on a regular basis, no front air damn will help with cooling as well. |
cpavlenko |
Jul 17 2014, 03:05 PM
Can anybody take pictures for placement on both sides. I have a haynes manual that shows measurements, but picture not to good. I've heard placement is very important. (IMG:style_emoticons/default/idea.gif)
7TPorsh |
Jul 17 2014, 03:38 PM
there is a pic in the Haynes manual...dont have it handy.
cpavlenko |
Jul 17 2014, 04:20 PM
Yea, I c the pic on haynes manual, not to good. Shows measurements, but is placement important. I've heard it is.
ClayPerrine |
Jul 17 2014, 06:05 PM
Life's been good to me so far..... Group: Admin Posts: 15,465 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
What would running a deeper section of stiff rubber across the full width and back along the sides a little do for cooling? That might not be as efficient. They are placed to specifically aid the air flow where the air comes down from the cylinders. When you look at the underside with the car on the lift, you can see that Porsche was aiming for those two spots in particular to help with moving the hot air away from under the cylinders. A lip over the full width might actually hinder cooling ... (IMG:style_emoticons/default/idea.gif) PS: Are you running a rear valance? That will trap hot air. Also, unless you go over 100mph on a regular basis, no front air damn will help with cooling as well. Andy... I think you are wrong about this..... but I could be wrong too. If you put a strip across the whole width of the engine compartment, you create a low pressure area behind it. That will help pull air through the engine and out the back. That's why it works to remove the rear valence, it allows more of the low pressure area behind the car to pull air from under it. If you really want to increase cooling and downforce, reverse the airflow over the engine. Pull air from the bottom, and exhaust it out the top. The Chaparrell sucker cars did this in 1970 Can am series. "Officially known as the 2J, the 1970 Chaparral has gone into history as the 'sucker car'. Setting aside his long experience with wings and aerofoil, Hall found a completely new way of generating downforce and without the penalty of additional drag. Using a Rockwell snowmobile engine, all the air was sucked from underneath the car creating a low pressure area; the 2J was literally sucked to the ground. The two cylinder engine was installed on top of the gearbox and the air was blown out the back by two large fans. The area was sealed off by lexan skirts that were connected to the suspension to keep them attached to the ground at all time." One of the problems a 914 has at high speed is the body starts to lift in the front. Adding a air dam at the front improves it tremendously. It also improves the airflow through the GT oil cooler because the exit is in the low pressure area behind the air dam. I have considered trying this for a long time. I am going to make a strip from rubber and run it the width of my car. I will let everyone know if it works or not. |
damesandhotrods |
Jul 17 2014, 07:50 PM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
If you really want to increase cooling and downforce, reverse the airflow over the engine. Pull air from the bottom, and exhaust it out the top. The Chaparrell sucker cars did this in 1970 Can am series. Mark Donohue managed to get Porsche to try this very idea with 917/10. It didn’t work… |
luskesq |
Jul 17 2014, 09:23 PM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
This link has a pic or two regarding placement (not very good) but when I did '70 I relied on the Haynes measurements. http://www.914world.com/bbs2/index.php?showtopic=102763
Keith |
Jul 17 2014, 09:44 PM
Yea, I c the pic on haynes manual, not to good. Shows measurements, but is placement important. I've heard it is. The link i gave you above shows you the exact measurement of where they are mounted ... (IMG:style_emoticons/default/shades.gif) |
dale73914 |
Jul 17 2014, 10:00 PM
Member Group: Members Posts: 209 Joined: 15-September 11 From: Victoria, Australia Member No.: 13,562 Region Association: Australia and New Zealand |
hmmm, i only remember seeing one of these under my car.
Might have to have a look tonight when i get home from work. Edwin, if i remember correctly , your in Melbourne too. If i have two, and you want to see them as a point of reference, your more than welcome to come over and have a snoop. Cheers Dale |
pete000 |
Jul 17 2014, 11:26 PM
Would a 914-6 benefit from these?
cpavlenko |
Jul 18 2014, 12:18 PM
Thanks for the link SirAndy...
Lo-Fi Version | Time is now: 17th May 2024 - 06:22 PM |
