Mid Engine Transmissions, I been thinking |
andys |
Jan 21 2005, 06:09 PM
Once you get into "Be able to handle long drawn out burn outs", and 450+HP, the transaxle choices become pretty slim AND expensive. The 930 is a good choice, not hugely expensive, good ratio's, plenty of adapters, needs flipped ring gear (with machining), or run up-side-down (with minor mod's). ZF takes the cost issue to the next level, as does the G50, and so on (Mendeola, Fortin, EMCO, Quaife). The Audi stuff will very likely never withstand that burn-out thing. The GT40 replica guys are putting 400HP or so thru the 016, but you must be nice to it. That said, you can probably find an ample supply of them in the junk yards for cheap, but I don't see the point. May as well stick with your supply of 901's. Transaxle longevity depends much on your driving style, and it sounds as if you're looking for throwing some pretty severe pounding at it. No M22's or Top Loader's in this catagory. Andy |
redshift |
Jan 21 2005, 06:23 PM
I was just saying to section it up, and see that most of the weight to the rear is real close to the rear. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
Jan 21 2005, 06:37 PM
Custom Member Group: Members Posts: 24,571 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
who cares |
Mueller |
Jan 21 2005, 08:24 PM
I still stand by my thoughts on the MR2 (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
I'm not the only one...Road&Track and cars.com thinks the same way:
now back to the original post, I think rich is looking for the holy-grail of transmissions (for us "frugal" 914 owners) I don't think they is going to be a sub $3k transaxle that's going to handle being abused with 450+ hp one thing to ponder, the size/type of tire can influence how long the transmission will last....sticky wide tires will cause the transmission to see more stress than skinny or harder tires.... |
SpecialK |
Jan 21 2005, 08:40 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
WOW....for a second I thought I was still on jwalter's "Bus 4 speed" thread (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) . Well there you go, how about a beefed up bus tranny?
Mueller |
Jan 21 2005, 08:42 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) I'd look into that for sure.... |
Brett W |
Jan 21 2005, 09:00 PM
The Audi tranny comes from the 5000 Turbo Quattro. It seems to be logical choice for us. You will have to design a shift linkage and get custom axels, but it will hold 450+ in out applications.
One thing to remember about a tranny and its capability to handle torque, when you are moving 3000+ lbs worth of car your tranny will be under more stress as you up the horsepower levels. So if you drop the tranny from a 5000 or boxster, etc in a teener and lighten accordingly your tranny's HP tolerance should go up. |
cha914 |
MUSR 8 - 5lug conversion done wed - drive 500miles thrus Group: Members Posts: 739 Joined: 31-December 02 From: Austin, TX Member No.: 63 |
Yep, seen lots of v8 sand cars use these...pretty cheap to get a beefed up one even...and the axels are bigger right?
http://www.ranchoperformance.com/transaxles/vw.html |
xsboost90 |
Jan 21 2005, 09:09 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
all these ideas and no mention of a 944/951 trans? a 944 trans is pretty tough and a 951 even more so though gearing is slightly higher. The 928 trans is much bigger IIRC. Either way they sit in the rear and have half shafts. Old 924's have "Thing" halfshafts, should be close to length.
michel richard |
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
Don't forget about the side shift thing, though. |
Brett W |
Jan 21 2005, 09:48 PM
The 944-951 tranny is the same one as the audi box from what I understand. I believe it is wider so you have to either widen the track or get shorter axles.
andys |
Jan 22 2005, 12:17 AM
Brett, Well they're close to the Audi 016 (Audi 5000), but differ in that the 951 (016R) has no provision for the clutch/TO bearing, and the input shaft is different. The 951 input shaft does have heat treated gears, an integral oil cooler pump, and a 3.375:1 R&P. The trans and R&P ratio's differ from the Audi version. Bummer is, that the parts that matter cannot be swapped with the Audi trans parts for a hybrid. With the right selection of parts, you can swap the R&P. The Quattro version of the 016 is rated higher simply because you split the torque between two differentials through a Thorsen. This holds true for the newer model 01E 6 speed Quattro trans, though it seems to be somewhat more durable than the earlier model 016 5 speed Quattro. I like the "out of the box" thinking with regard to the bus trans. There has been a ton of racing development on these, and you (jwalter) just might be on to something very interesting. Andy |
Brett W |
Jan 22 2005, 01:12 AM
Yes I thought they would be a little different. You can get the Audi tranny for 150$ all day long, yet the 951 tranny would probably cost you a bit more.
http://www.lambolounge.com/Chassis/Transmi...i-915/index.asp http://www.lambolounge.com/Chassis/Transmi...n/5000/5000.asp http://elektro.cmhnet.org/~charlie/photos/.../01E/trans.html http://webpages.charter.net/jims80/M6B-GT/...nginetrans.html |
Lo-Fi Version | Time is now: 4th May 2024 - 12:21 AM |
