FS. Engman Fuse panel, clear plastic cover missing |
mikea100 |
Jul 18 2014, 09:00 PM
Member Group: Members Posts: 180 Joined: 28-December 09 From: Edison, NJ Member No.: 11,182 Region Association: North East States |
Engman Fuse panel, clear plastic box missing $60 + shipping
tweet |
Jul 18 2014, 10:07 PM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
Can you post pictures of the back side?
mikea100 |
Jul 19 2014, 06:15 AM
euro911 |
Jul 19 2014, 03:31 PM
Markl |
Jul 19 2014, 03:47 PM
Member Group: Members Posts: 75 Joined: 14-September 09 From: Colorado Member No.: 10,802 Region Association: Rocky Mountains |
I'll take this - sending PM
914itis |
Jul 19 2014, 04:08 PM
2nd
bdstone914 |
Jul 19 2014, 07:02 PM
bdstone914 Group: Members Posts: 4,521 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
A word of caution to anyone installing an Engman fuse panel on an early car.
The early 70-72 cars have a positive terminal block just to the left and above the fuse panel. After installing one and even shrink tubing the metal bracket the positive wire arced to the bracket on the panel and nearly started a fire. I moved the terminal block to the other side to where it was originally mounted to eliminate the problem. And I found the the jumpers between the four fuses that power the headlight were wrong. I had to rewire the pair of fuses to make the low and high beams operate correctly. You can not see the jumpers unless you remove the bracket and the plastic cover. |
914itis |
Jul 19 2014, 08:13 PM
A word of caution to anyone installing an Engman fuse panel on an early car. The early 70-72 cars have a positive terminal block just to the left and above the fuse panel. After installing one and even shrink tubing the metal bracket the positive wire arced to the bracket on the panel and nearly started a fire. I moved the terminal block to the other side to where it was originally mounted to eliminate the problem. And I found the the jumpers between the four fuses that power the headlight were wrong. I had to rewire the pair of fuses to make the low and high beams operate correctly. You can not see the jumpers unless you remove the bracket and the plastic cover. Thanks Bruce . I found that out the hard way the first time I installed one on my 70 |
Lo-Fi Version | Time is now: 15th May 2024 - 10:37 PM |
