Where do you find these gaskets? |
cary |
Jul 20 2014, 08:52 AM
I pulled the engine to replace the oil pump cover .... drip, drip, drip.
But this gasket came apart when I pulled the heater tin. It goes inside heater tin that attaches to blower housing. #24. Keeps moisture from getting inside the heating system I assume. Dug thru both AA and Pelican and found nothing. Made an attempt at Bus Depot but I have no idea what its called or the part number. I know that I replaced them around 7-8 years ago. |
injunmort |
Jul 20 2014, 09:26 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
try 914rubber, vendor on this site
type47 |
Jul 20 2014, 09:35 AM
I think what you're looking for is called a "branch piece gasket" by AA. From the PET 202-15, no figure number as it doesn't seem to appear in the figure,
021.256.325 A gasket for cover and 021.256.326 A " here is the part in AA: skip this link http://www.autoatlanta.com/results.php if the link doesn't show the part, search the AA catalog for 021.256.325A (and don't search for 021.256.325 A, notice the space before the "A") and the link above doesn't get to the part. Try http://www.autoatlanta.com/porsche-parts/h...;section=202-15 and scroll down, the gaskets are in the parts list after 18 and (18) ... see also: http://www.914world.com/bbs2/index.php?showtopic=215402 |
barefoot |
Jul 20 2014, 09:55 AM
Senior Member Group: Members Posts: 1,269 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
My tins are missing these gaskets. Rather than pay the big $$ from AA i plan on using hight temp silicone sealant to keep warm air leakage to a minimum. It also may help rattles away.
larryM |
Jul 20 2014, 09:34 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
hardware store - std household door seals - glue 'em on with rtv
p.s. - the Parade concours judges will never know you don't have a 100 point car if you do this |
bdstone914 |
Jul 21 2014, 12:49 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
hardware store - std household door seals - glue 'em on with rtv p.s. - the Parade concours judges will never know you don't have a 100 point car if you do this Not sure how well a household seal will hold up to the heat. Mike Blizzard was going to make them by 3d printing. I have a very old roll of asbestos paper that I am going to use to make some. |
TeenerTech |
Jul 21 2014, 09:37 PM
some mechanic Group: Members Posts: 17 Joined: 21-July 14 From: Grand Rapids, MI Member No.: 17,667 Region Association: North East States |
I don't think the heat will be an issue considering that seal is on the cold side of the heat exchanger getting cool air blown over it at all times.
I removed all my heater boxes and parts right after a long drive and was able to grab a hold of it and not get burned!!! |
cary |
Jul 21 2014, 10:38 PM
Here's the closest thing I've found.
http://www.mcmaster.com/#packing-seals/=sxxeq1 But we need 1/4 * 3/16, not 1/4 *1/4. Bus Depot got back to me this afternoon. No go ..... |
rhodyguy |
Jul 22 2014, 08:14 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
make an RTV bead where the gasket would lay on the branch piece sit and let it set up before installing. that way you're not 'glueing' them together. iirc the gasket from the 'other place' are fairly spendy.
saigon71 |
Jul 23 2014, 06:34 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I made some with thick cork gasket material from FLAPS and glued them in with RTV. It worked well.
cary |
Sep 21 2014, 09:45 AM
Here's what I finally did. It's been curing since July. As you can see I only filled in the missed section. Should work.
Bartlett 914 |
Sep 21 2014, 10:20 AM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I used an O-ring I had around. It sealed both top and bottom in one shot. Worked pretty good. You could also use o-ring cord stock and glue in place
pilothyer |
Sep 21 2014, 10:44 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I bought one of those red silicone flexible baking pans and cut out the seals and glued them in place with high temp silicone glue. they have always worked well and stayed in place even after a few "take off and put backs"
Mikey914 |
Sep 21 2014, 10:52 AM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Pretty easy to make. And pretty cheap too. If you guys want me to make them I can in high temp silicone.
I'd guess about $2 a pop |
bdstone914 |
Sep 21 2014, 10:59 AM
Pretty easy to make. And pretty cheap too. If you guys want me to make them I can in high temp silicone. I'd guess about $2 a pop That would be great if you made them. You probably know the left and right sides are different sizes. I would take a few pairs. Bruce |
Larmo63 |
Sep 21 2014, 01:07 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
914s have heaters? (IMG:style_emoticons/default/blink.gif)
bandjoey |
Nov 18 2014, 03:15 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
anyone making these? couldn't find them on 914rubber or anywhere else. if not i'll just layer gasket material and make them fit.
rhodyguy |
Nov 18 2014, 05:54 PM
What crap! $33.85 for one side and $38.54 for the other plus what ever they charge for 'handling' (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/mad.gif) Oh mark....now I remember why I don't frequent the AA site
913B |
Nov 18 2014, 10:52 PM
Senior Member Group: Members Posts: 845 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
mapguy |
Nov 18 2014, 11:30 PM
Freelance Generalist Group: Members Posts: 90 Joined: 31-January 14 From: Inland Empire, CA Member No.: 16,945 Region Association: Southern California |
I would also be interested in a set, provided I can get my grill badge by the time you pop them (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/poke.gif) |
Lo-Fi Version | Time is now: 29th April 2024 - 04:36 AM |
