Where do you find these gaskets? |
cary |
Jul 20 2014, 08:52 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
I pulled the engine to replace the oil pump cover .... drip, drip, drip.
But this gasket came apart when I pulled the heater tin. It goes inside heater tin that attaches to blower housing. #24. Keeps moisture from getting inside the heating system I assume. Dug thru both AA and Pelican and found nothing. Made an attempt at Bus Depot but I have no idea what its called or the part number. I know that I replaced them around 7-8 years ago. |
rhodyguy |
Jul 22 2014, 08:14 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,080 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
make an RTV bead where the gasket would lay on the branch piece sit and let it set up before installing. that way you're not 'glueing' them together. iirc the gasket from the 'other place' are fairly spendy.
Lo-Fi Version | Time is now: 15th May 2024 - 10:54 PM |
