Where do you find these gaskets? |
cary |
Jul 20 2014, 08:52 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
I pulled the engine to replace the oil pump cover .... drip, drip, drip.
But this gasket came apart when I pulled the heater tin. It goes inside heater tin that attaches to blower housing. #24. Keeps moisture from getting inside the heating system I assume. Dug thru both AA and Pelican and found nothing. Made an attempt at Bus Depot but I have no idea what its called or the part number. I know that I replaced them around 7-8 years ago. |
Bartlett 914 |
Sep 21 2014, 10:20 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I used an O-ring I had around. It sealed both top and bottom in one shot. Worked pretty good. You could also use o-ring cord stock and glue in place
Lo-Fi Version | Time is now: 16th May 2024 - 04:11 AM |
