when installing PMB r control arm bushings, need a quick answer |
rhodyguy |
Jul 20 2014, 11:03 AM
a local member has his car in my garage and we all ready did the f strut inserts. now moving to the back of the car. do eric's bushings require any sort of high pressure grease on the bushings prior to install? eric must be busy, jim left him a phone message.
Black22 |
Jul 20 2014, 11:56 AM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
a local member has his car in my garage and we all ready did the f strut inserts. now moving to the back of the car. do eric's bushings require any sort of high pressure grease on the bushings prior to install? eric must be busy, jim left him a phone message. I believe there is a video (or a couple of them) on YouTube from Eric. I did this recently and used Hi Temp Disc Brake wheel bearing grease. Not a lot, but a liberal amount. Try this one, start watching the video at the 9 minute mark: https://www.youtube.com/watch?v=0as7HlXDj6M Have fun! |
914_teener |
Jul 20 2014, 12:27 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I did a thread on this last Summer.
When I talked to Erc....he had me bond the bushings to the control arms with JB Weld. I then shaved them down so that the serrated shoulder on the pivot arm engaged the console mount. I installed a zerk fitting on each bushing and there was a recommendation for the grease from Eric... a slicone product...I'll have to find the thread as I have run out since I installed mine. That was two Summers ago...no problems. |
Lo-Fi Version | Time is now: 17th May 2024 - 06:03 PM |
