Turn Signal switch |
914_8 |
Jul 22 2014, 07:54 PM
Newbie Group: Members Posts: 40 Joined: 3-November 13 From: Saugus, Ca Member No.: 16,601 Region Association: Southern California |
So, I am finally getting around to getting my 914 on the road. I am sorting out the lighting system, and have all working except the turn signals, high beams and dash lights. I haven't torn into it too deep yet, but i did pull the steering wheel and hit the switch with a test light/power probe. I have no juice on any wire but the horn wire…… I did notice that the switch was brittle and worn badly. My question is, is the dash lighting circuit tied into the signal switch? And who sells the best turn signal switch? the only source I have found is AA (yeah I know)….. the car is a 75 2.0 that I converted to a V8.
Attached thumbnail(s) |
barebrad |
Jul 22 2014, 11:14 PM
Member Group: Members Posts: 54 Joined: 13-September 13 From: Huntsville, Al Member No.: 16,382 Region Association: South East States |
I just replaced my turn signal switch and wiper switch. For the turn signal switch, I purchased a VW beetle switch from CIP. Part number VWC-111-953-513-F. Works perfect.
914_8 |
Jul 23 2014, 07:07 PM
Thanks for the link. Unfortunately, CIP is out of stock. Looks like I am stuck ordering from ''those guys''
914Sixer |
Jul 23 2014, 07:09 PM
914 Guru Group: Members Posts: 8,872 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Try autohausaz.com. $23 Pull up 75 Beetle and order from there.
Valy |
Jul 23 2014, 07:34 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
You want this:
http://www2.cip1.com/ProductDetails.asp?Pr...C-111-953-519-G 111-953-519-G They have it in stock but HalfMoon just struggled with one that had 2 connector wires switched. Easy to fix once you know what the problem is. The extra wire is for your optional wipers water pump. |
914_8 |
Jul 24 2014, 11:01 PM
Thanks guys.
Lo-Fi Version | Time is now: 2nd May 2024 - 10:35 AM |
