WTB Front 5 lug hubs |
Alapone |
Jul 23 2014, 06:00 AM
Member Group: Members Posts: 105 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None |
I recently purchased a set of 1974 911 boge struts. Need to buy front hubs with lugs and backing plate.
Also anybody have rear 5x130 drilled 914-4 rotors? need those too. Thanks. |
euro911 |
Jul 23 2014, 01:27 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,846 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I have a pair of brand new 5-lug rear rotors from PMB that I won't be using since I decided to stay with ATS Classics 4-lug wheels.
$150. shipped (CONUS) |
bdstone914 |
Jul 23 2014, 02:19 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I have a pair of brand new 5-lug rear rotors from PMB that I won't be using since I decided to stay with ATS Classics 4-lug wheels. $150. shipped (CONUS) Good price on the rotors but be aware that the true 914-6 rotors have the two screw holes for in a different location then the 914 rotors. If they are redrilled 914 rotors the holes line up. |
bdstone914 |
Jul 23 2014, 06:18 PM
I have a pair of brand new 5-lug rear rotors from PMB that I won't be using since I decided to stay with ATS Classics 4-lug wheels. $150. shipped (CONUS) Good price on the rotors but be aware that the true 914-6 rotors have the two screw holes for in a different location then the 914 rotors. If they are redrilled 914 rotors the holes line up. I do have a pair of 911 backing plates that were powder coated satin black. I think the cut out is for m calipers. If you are running S or A calipers they would need to be trimmed. Asking $50 for the pair shipped. Attached thumbnail(s) |
Alapone |
Jul 24 2014, 05:19 AM
euro911 |
Jul 24 2014, 03:26 PM
Yes.
Alapone |
Aug 5 2014, 05:56 AM
Still looking for these if anyone can help.
mskala |
Aug 5 2014, 06:30 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Still looking for these if anyone can help. I have a pair of fronts with lugs that you can have for shipping cost. Basically they came off my -6 when I was trying to fix another issue and I noticed after cleaning that the anodizing in some of the recessed areas is coming off and starting to get pitting. They will work fine but at some point need to be protected from more corrosion. PM me for photos if interested. |
bdstone914 |
Aug 5 2014, 06:39 AM
Still looking for these if anyone can help. I have a pair of fronts with lugs that you can have for shipping cost. Basically they came off my -6 when I was trying to fix another issue and I noticed after cleaning that the anodizing in some of the recessed areas is coming off and starting to get pitting. They will work fine but at some point need to be protected from more corrosion. PM me for photos if interested. I don't think the hubs from a 6 will fit the 74 struts he has. Yours fit on 16 mm spindles and you ones he needs for on 18 mm spindles. |
mskala |
Aug 5 2014, 08:00 AM
Still looking for these if anyone can help. I have a pair of fronts with lugs that you can have for shipping cost. Basically they came off my -6 when I was trying to fix another issue and I noticed after cleaning that the anodizing in some of the recessed areas is coming off and starting to get pitting. They will work fine but at some point need to be protected from more corrosion. PM me for photos if interested. I don't think the hubs from a 6 will fit the 74 struts he has. Yours fit on 16 mm spindles and you ones he needs for on 18 mm spindles. I'm fairly sure that all the 911 struts of that time window are the same in the bearing taper area. Will try to double-check later. |
johnhora |
Aug 5 2014, 12:44 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
I have a pair front hubs from a 73' 911 available
johnhora |
Aug 6 2014, 12:27 PM
Alapone...
sent you a pm but just noticed in your post the struts you have are from a 74'.... what I have are two hubs from 74-89' 911 part no 911.341.605.4R I also have the bearings and stock 45mm studs $80 for all shipped USA48 Thanks...john |
Alapone |
Aug 12 2014, 11:40 AM
I was able to get a set of these thanks for the help guys.
brant |
Aug 12 2014, 06:54 PM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
John. I'm interested if still available
euro911 |
Aug 15 2014, 04:42 AM
So did the rear rotors meet your expectations, Andrew?
(inquiring minds ...) (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 29th April 2024 - 03:28 PM |
