WTB Front 5 lug hubs |
Alapone |
Jul 23 2014, 06:00 AM
Member Group: Members Posts: 105 Joined: 4-April 13 From: Nj Member No.: 15,734 Region Association: None |
I recently purchased a set of 1974 911 boge struts. Need to buy front hubs with lugs and backing plate.
Also anybody have rear 5x130 drilled 914-4 rotors? need those too. Thanks. |
Alapone |
Aug 5 2014, 05:56 AM
Still looking for these if anyone can help.
mskala |
Aug 5 2014, 06:30 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Still looking for these if anyone can help. I have a pair of fronts with lugs that you can have for shipping cost. Basically they came off my -6 when I was trying to fix another issue and I noticed after cleaning that the anodizing in some of the recessed areas is coming off and starting to get pitting. They will work fine but at some point need to be protected from more corrosion. PM me for photos if interested. |
bdstone914 |
Aug 5 2014, 06:39 AM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Still looking for these if anyone can help. I have a pair of fronts with lugs that you can have for shipping cost. Basically they came off my -6 when I was trying to fix another issue and I noticed after cleaning that the anodizing in some of the recessed areas is coming off and starting to get pitting. They will work fine but at some point need to be protected from more corrosion. PM me for photos if interested. I don't think the hubs from a 6 will fit the 74 struts he has. Yours fit on 16 mm spindles and you ones he needs for on 18 mm spindles. |
mskala |
Aug 5 2014, 08:00 AM
Still looking for these if anyone can help. I have a pair of fronts with lugs that you can have for shipping cost. Basically they came off my -6 when I was trying to fix another issue and I noticed after cleaning that the anodizing in some of the recessed areas is coming off and starting to get pitting. They will work fine but at some point need to be protected from more corrosion. PM me for photos if interested. I don't think the hubs from a 6 will fit the 74 struts he has. Yours fit on 16 mm spindles and you ones he needs for on 18 mm spindles. I'm fairly sure that all the 911 struts of that time window are the same in the bearing taper area. Will try to double-check later. |
Lo-Fi Version | Time is now: 16th May 2024 - 09:21 AM |
