FS Tachometer, Converted for a 6 |
Timmyjr11 |
Jul 25 2014, 08:48 PM
Newbie Group: Members Posts: 4 Joined: 30-March 14 From: Indiana Member No.: 17,179 Region Association: None |
My dad and I worked on this gauge together. It is a standard tachometer for the 914, but has been modified with modern servo tach drive. This tachometer has been calibrated for a six cylinder.
This tachometer will work with all signal inputs, so no tach converter is necessary. For the people that put a six cylinder in your 914, this is the tachometer for you! Asking $350, which will help my funds for buying a 914 before I turn 16 (IMG:style_emoticons/default/driving.gif) |
Timmyjr11 |
Aug 10 2014, 07:41 PM
Thank you, yes it will work with your ECU signal. Also, the terminals on the back are still the same. The right terminal is +12 volts, middle is the signal terminal, and the left side is the ground terminal.
Lo-Fi Version | Time is now: 15th May 2024 - 12:20 PM |
