WTB early glove box, clean, unmolested |
porbmw |
Jul 29 2014, 08:53 AM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Need to recover from a stall on this project, have discovered it is now about 8 years since car came apart.
So need to locate a very clean, early glove box (from the early cars, which came without dash vents....box is wider than later version) Thanks Paul |
Phoenix-MN |
Jul 29 2014, 09:46 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Need to recover from a stall on this project, have discovered it is now about 8 years since car came apart. So need to locate a very clean, early glove box (from the early cars, which came without dash vents....box is wider than later version) Thanks Paul I should have one from a '71. I'll check tonight when I get home Paul |
porbmw |
Jul 29 2014, 10:39 AM
Need to recover from a stall on this project, have discovered it is now about 8 years since car came apart. So need to locate a very clean, early glove box (from the early cars, which came without dash vents....box is wider than later version) Thanks Paul I should have one from a '71. I'll check tonight when I get home Paul From Paul to Paul Thanks. |
Phoenix-MN |
Jul 31 2014, 05:07 PM
Sorry, it took me a while to find it. It is an early one but has a nasty hole in the side (all the pieces are there) it could be repaired (IMG:style_emoticons/default/smash.gif) Pay for shipping and you can have it.
Paul |
porbmw |
Aug 1 2014, 02:05 PM
Sorry, it took me a while to find it. It is an early one but has a nasty hole in the side (all the pieces are there) it could be repaired (IMG:style_emoticons/default/smash.gif) Pay for shipping and you can have it. Paul Thanks for checking,Paul. I think I have it's sister glove box...mine too has a hole...I'm guessing the previous owner put a hole in the bottom to run some wires into the box. I very much appreciate the offer. I know it's a hassle to ship stuff. If you don't mind, let me fish around theworld for one that doesn't need repair....failing which, I will practise my repair skills on my semi destroyed box....and if it looks like I'm getting the hang of doing a decent repair, will shoot you an email if you still have the box hanging about. Thanks again Paul |
Lo-Fi Version | Time is now: 16th May 2024 - 08:10 AM |
