Cracked Fuch, Can this be repaired |
larryg |
Jul 30 2014, 11:00 AM
Newbie Group: Members Posts: 37 Joined: 5-February 14 From: portland oregon Member No.: 16,961 Region Association: None |
Am having 4 spoke fuchs polished and discovered a crack. Am sending it out to see if it can be safely repaired. Thoughts?
carr914 |
Jul 31 2014, 05:25 AM
Racer from Birth Group: Members Posts: 118,626 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
This just points out for people to check your wheels regularly. A Forge Wheel should be the strongest wheel out there - much stronger than Cast Wheels and much Stronger than the aftermarket (for the most part) wheels.
As much as I think they are the best looking wheel for a 914-6, I would never put a set of the Mahle Gas-Burners on a car. They were the Lightest Wheel ever put on a Porsche due to their Magnesium construction. However Mag gets brittle as it gets older (one of the "new" problems of older 911 Engines), developes cracks & break |
mepstein |
Jul 31 2014, 07:38 AM
914-6 GT in waiting Group: Members Posts: 19,271 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
This just points out for people to check your wheels regularly. A Forge Wheel should be the strongest wheel out there - much stronger than Cast Wheels and much Stronger than the aftermarket (for the most part) wheels. As much as I think they are the best looking wheel for a 914-6, I would never put a set of the Mahle Gas-Burners on a car. They were the Lightest Wheel ever put on a Porsche due to their Magnesium construction. However Mag gets brittle as it gets older (one of the "new" problems of older 911 Engines), developes cracks & break Does it get brittle with age or use(work harden, heat, ect) I didn't realize age would change a metal's structure. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:17 PM |
