What pistons? |
What pistons? |
shandyhaggis |
Jul 31 2014, 05:17 AM
Newbie Group: Members Posts: 49 Joined: 2-February 11 From: UK Member No.: 12,653 Region Association: None |
Hi all
Im restoring a US 1976 2.0 with a 1973 2.0 engine (not sure how that happened but hey). Im in the UK and these are as rare as hens teeth. Ive decided to retrofit a standard FI system (currently gathering the relevant bits). My engine builder has suggested a Web cam - WEB #73 262/262 duration 0.426 lift which I believe is correct. Any ideas on what pistons I should use? The 73 engine has bus pistons which are in good shape but if Im going to the expense of rebuilding then I feel I should put something better back in. Im not looking to build a hot rod just a nice reliable fun motor. My engine chap is suggesting Keith and Black pistons (96mm). Would that work or are there better options? thanks Andrew |
Cap'n Krusty |
Jul 31 2014, 09:55 AM
While the nice folks at Web Cam mean well, they've been saying for decades that this cam works with D-jet, and it does, if you don't mind low vacuum and poor performance (including idle) under about 2000 RPM. I suggest you look elsewhere for your camshaft. The stock grind is best for the money, and it is said that Jake Raby has a camshaft that works well. Remember to buy lifters from the same source as you buy your camshaft. If I were you, I would purchase a set of factory pistons and cylinders. They're readily available, and the quality is high, unlike most of the less expensive aftermarket brands (which are made in China).
The Cap'n |
Lo-Fi Version | Time is now: 17th May 2024 - 07:56 AM |
