What pistons? |
What pistons? |
shandyhaggis |
Jul 31 2014, 05:17 AM
Newbie Group: Members Posts: 49 Joined: 2-February 11 From: UK Member No.: 12,653 Region Association: None |
Hi all
Im restoring a US 1976 2.0 with a 1973 2.0 engine (not sure how that happened but hey). Im in the UK and these are as rare as hens teeth. Ive decided to retrofit a standard FI system (currently gathering the relevant bits). My engine builder has suggested a Web cam - WEB #73 262/262 duration 0.426 lift which I believe is correct. Any ideas on what pistons I should use? The 73 engine has bus pistons which are in good shape but if Im going to the expense of rebuilding then I feel I should put something better back in. Im not looking to build a hot rod just a nice reliable fun motor. My engine chap is suggesting Keith and Black pistons (96mm). Would that work or are there better options? thanks Andrew |
Java2570 |
Jul 31 2014, 08:12 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Call European Motorworks - they are great and have very good prices. Also, Type 4 store has been very good as well. On my current 2.0L D Jet engine I rebuilt, I used a stock cam grind from EMW and reused my flat top KS pistons. I'm not sure I'd go with a Webcam 73 cam for an otherwise stock engine with D Jet. I ended up with buying a cam kit from Type 4 store (9590) and KB pistons and jugs from EMW. I have not built this engine (2056) yet as I'm still gathering some parts but I've read that the 9590 cam will be a better fit for D Jet than the Web 73....although some tuning will be required for any non stock cam setup. Anyway, my 2 cents only, talk to more of the great folks here! Jon |
shandyhaggis |
Jul 31 2014, 09:59 AM
(IMG:style_emoticons/default/agree.gif) Call European Motorworks - they are great and have very good prices. Also, Type 4 store has been very good as well. On my current 2.0L D Jet engine I rebuilt, I used a stock cam grind from EMW and reused my flat top KS pistons. I'm not sure I'd go with a Webcam 73 cam for an otherwise stock engine with D Jet. I ended up with buying a cam kit from Type 4 store (9590) and KB pistons and jugs from EMW. I have not built this engine (2056) yet as I'm still gathering some parts but I've read that the 9590 cam will be a better fit for D Jet than the Web 73....although some tuning will be required for any non stock cam setup. Anyway, my 2 cents only, talk to more of the great folks here! Jon Thanks Jon sadly I think the webcam is already 'purchased' by the builder so Im obliged to go with it. I will contact Euro motorworks though. I need to read more about the standard FI for the 2.0. What are you able to adjust for tuning? I thought it was a fairly sealed thing with only a co adjustment. Ive got soo much to learn :-) Thankfully Im in the right place! thanks Andrew |
Lo-Fi Version | Time is now: 17th May 2024 - 01:09 PM |
