What pistons? |
What pistons? |
shandyhaggis |
Jul 31 2014, 05:17 AM
Newbie Group: Members Posts: 49 Joined: 2-February 11 From: UK Member No.: 12,653 Region Association: None |
Hi all
Im restoring a US 1976 2.0 with a 1973 2.0 engine (not sure how that happened but hey). Im in the UK and these are as rare as hens teeth. Ive decided to retrofit a standard FI system (currently gathering the relevant bits). My engine builder has suggested a Web cam - WEB #73 262/262 duration 0.426 lift which I believe is correct. Any ideas on what pistons I should use? The 73 engine has bus pistons which are in good shape but if Im going to the expense of rebuilding then I feel I should put something better back in. Im not looking to build a hot rod just a nice reliable fun motor. My engine chap is suggesting Keith and Black pistons (96mm). Would that work or are there better options? thanks Andrew |
Java2570 |
Jul 31 2014, 08:12 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Call European Motorworks - they are great and have very good prices. Also, Type 4 store has been very good as well. On my current 2.0L D Jet engine I rebuilt, I used a stock cam grind from EMW and reused my flat top KS pistons. I'm not sure I'd go with a Webcam 73 cam for an otherwise stock engine with D Jet. I ended up with buying a cam kit from Type 4 store (9590) and KB pistons and jugs from EMW. I have not built this engine (2056) yet as I'm still gathering some parts but I've read that the 9590 cam will be a better fit for D Jet than the Web 73....although some tuning will be required for any non stock cam setup. Anyway, my 2 cents only, talk to more of the great folks here! Jon |
shandyhaggis |
Jul 31 2014, 09:59 AM
(IMG:style_emoticons/default/agree.gif) Call European Motorworks - they are great and have very good prices. Also, Type 4 store has been very good as well. On my current 2.0L D Jet engine I rebuilt, I used a stock cam grind from EMW and reused my flat top KS pistons. I'm not sure I'd go with a Webcam 73 cam for an otherwise stock engine with D Jet. I ended up with buying a cam kit from Type 4 store (9590) and KB pistons and jugs from EMW. I have not built this engine (2056) yet as I'm still gathering some parts but I've read that the 9590 cam will be a better fit for D Jet than the Web 73....although some tuning will be required for any non stock cam setup. Anyway, my 2 cents only, talk to more of the great folks here! Jon Thanks Jon sadly I think the webcam is already 'purchased' by the builder so Im obliged to go with it. I will contact Euro motorworks though. I need to read more about the standard FI for the 2.0. What are you able to adjust for tuning? I thought it was a fairly sealed thing with only a co adjustment. Ive got soo much to learn :-) Thankfully Im in the right place! thanks Andrew |
reharvey |
Jul 31 2014, 10:24 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
(Sadly I think the webcam is already 'purchased' by the builder so Im obliged to go with it. I will contact Euro motorworks though. ) The Webcam 73 has worked well in my 74 2.0 D-jet. ( 15 yrs. ). I also have that cam in my 73 2.0 w/D-jet and it is runnind great. You'll need to find someone who really knows how to tune and adjust the D-jet system to work with whatever motor you build. If you don't know a guy that can do this for you then it's best to go stock all the way. The Bus pistons are deep dished and will give you really low compession so dump them for some flat top pistons. Ray |
shandyhaggis |
Jul 31 2014, 10:33 AM
(Sadly I think the webcam is already 'purchased' by the builder so Im obliged to go with it. I will contact Euro motorworks though. ) The Webcam 73 has worked well in my 74 2.0 D-jet. ( 15 yrs. ). I also have that cam in my 73 2.0 w/D-jet and it is runnind great. You'll need to find someone who really knows how to tune and adjust the D-jet system to work with whatever motor you build. If you don't know a guy that can do this for you then it's best to go stock all the way. The Bus pistons are deep dished and will give you really low compession so dump them for some flat top pistons. Ray thanks for that. Im going to have to ask around re tuning the d-jet (or learn myself) there may be 1 or 2 aficionados in the UK. Ill def go for flat tops, Im steering towards factory all the way. I dont like meddling with the unknown :-) thanks again Andrew |
Lo-Fi Version | Time is now: 17th May 2024 - 09:26 AM |
