Tilton, Quartermaster, etc Clutches, Racers |
Brett W |
Jan 22 2005, 10:27 PM
Advanced Member Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None |
What splines and disk are you guys using for your Tilton 3 disk clutch systems. Where are you getting your flywheels?
Otmar |
Jan 23 2005, 02:47 AM
2000 Amps in a 914 Group: Members Posts: 174 Joined: 3-March 03 From: Corvallis, OR, USA Member No.: 387 |
I used a 7-1/4" triple copper disc unit.
Originally on the stock 914 trans but using a smallblock ford V-8 flywheel pattern. Got drawings of the adaptor on my site. So far it all takes well over 1000 ft/lb without slipping. I have a spare set of stock splined discs that I don't need since when I upgraded to the 930 box it needed the larger splines. I'll let them go cheap! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Don't know if that helps any since it was all pretty custom. |
Thorshammer |
Jan 23 2005, 11:52 AM
Senior Member Group: Members Posts: 749 Joined: 11-November 03 Member No.: 1,335 |
Although I have a six for my EP car. The flywheel comes from Fidanza. Order now if you want something by the spring. They have aluminum flywheels for type 4 motors I am told. As far as the clutch goes Tilton 5.5 twin disc with standard splines, just call them they are very knowledgable. The release bearing can be tricky, but I think you could use the standard bearing with a reducer for this clutch. I had to engineer a hydraulic release bearing due to my odd (Hewland)transmission config.
Pics enclosed Erik Madsen Attached image(s) |
Britain Smith |
Jan 23 2005, 12:13 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Here is a picture of WEVO's flywheel on the tube frame 914 car.
(IMG:http://www.britainsmith.com/Porsche/Yeaman/images/128_2832_JPG.jpg) And here is the throw-out bearing. (IMG:http://www.britainsmith.com/Porsche/Yeaman/images/128_2838_JPG.jpg) |
Lo-Fi Version | Time is now: 17th May 2024 - 01:40 PM |
