Towing |
Towing |
00r101 |
Aug 4 2014, 02:35 AM
Newbie Group: Members Posts: 17 Joined: 24-May 12 From: United States Member No.: 14,476 Region Association: MidAtlantic Region |
If your car does not have a parking brake do you leave it in gear or just rely on the straps to secure it?
Rand |
Aug 4 2014, 02:39 AM
If your car does not have a parking brake do you leave it in gear or just rely on the straps to secure it? I think you are talking trailering, not towing. Strap it and block it. It's not about the parking brake. Who is transporting for you? This is only your problem if you hired Guido's x sisters son in law. If you are doing it by yourself and asking this... Good luck. Do you think there's a difference between in gear and neutral? Probably not enough to tow on a flatbed. Do you have any bricks? If so smack them on your head. |
naro914 |
Aug 4 2014, 06:59 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
If your car does not have a parking brake do you leave it in gear or just rely on the straps to secure it? I think you are talking trailering, not towing. Strap it and block it. It's not about the parking brake. Who is transporting for you? This is only your problem if you hired Guido's x sisters son in law. If you are doing it by yourself and asking this... Good luck. Do you think there's a difference between in gear and neutral? Probably not enough to tow on a flatbed. Do you have any bricks? If so smack them on your head. dude...I think that is a perfectly reasonable question, everyone had to learn to tow their first time, and when you modify your car and things you're used to are no longer there - like a parking brake - it's better to ask first than to find out the hard way. No need to be jerk about your response.... to answer your question, I leave it in gear then strap it down tight. The ONE TIME I left it out of gear in my enclosed trailer, one of the straps let go and it rolled back and forth, slightly damaging a fender. Honestly, the BEST way, although a bit more time consuming: pull on trailer, and either leave in gear or have someone chock the wheels. If left in gear, put one strap on to hold it, take out of gear so you're not stressing the trans. Strap down tight, then reach in and put back in gear. That's what I do now. Some may post and say not to put it in gear, puts undue stress on the trans, etc. My personal opinion and based on experience: leave it in gear. Good luck! |
Seabird |
Aug 4 2014, 09:03 AM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
If your car does not have a parking brake do you leave it in gear or just rely on the straps to secure it? I never trailer any of my cars in gear. I know folks who have/do but I wouldn't. The straps, which are cheap compared to you power train, though should not be the cheapest straps you can find, are what should be doing the work of securing the car. IF you are relying on the transmission to hold the car then any braking and acceleration forces are getting transferred into your transmission. Not a good thing. Think of it this way, which would you rather replace straps or a tranny? M PS: Straps tend to stretch a little while your towing (a little means a little less tension in them not the car can move back and forth an inch or more). If the straps loosen up a bit and you left it in gear your back to putting stress in your transmission. I like to drive maybe 10 miles and then pull over and check the straps, the lug nuts, and tire and hub temps. Better to take 5 mins doing this then three hours getting something fixed on the side of the road. This post has been edited by Seabird: Aug 4 2014, 09:11 AM |
naro914 |
Aug 4 2014, 09:14 AM
also...and against conventional wisdom...I recommend you DO NOT cross your straps.
think about it...if a strap lets go, the remaining strap is pulling the car to one side, thus being detrimental and causing more problems. If they are straight front to back, it will always try to keep it somewhat centered. Again, just my opinion but been trailering multiple cars for 20 years in many different configurations and trailers... |
campbellcj |
Aug 4 2014, 01:01 PM
I can't Re Member Group: Members Posts: 4,543 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
FWIW I have always trailered in gear - but I tighten all the straps while in neutral. The car moves around substantially when you are cinching it down.
My rationale is if a strap or two ever let go, I don't want the car to roll around (or totally off the trailer). If I had an enclosed trailer I'd probably chock the wheels and leave it in neutral, but I'm talking open trailer. Also, I do not cross the straps, and on longer tows I stop around the midpoint (if not more) to check and re-cinch. |
messix |
Aug 12 2014, 11:47 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
whats with all this stress the transmission talk.
if your only tensioning the straps and not dragging the car against the tranny in gear I don't see any real stress on the tranny. you should tension the front straps equally then do the rear, and the car should not move much at all. I have towed my jeep and teener in my toyhauler for years and always park it on the trailer then simply tight the strap. another reason to not leave it in gear is when you are removing the straps and you don't get a surprise because you forgot to put it back in gear. |
campbellcj |
Aug 12 2014, 11:56 PM
another reason to not leave it in gear is when you are removing the straps and you don't get a surprise because you forgot to put it back in gear. Another towing habit I've formed, mainly in case I did not put the car in gear or it popped-out somehow, is to never ever put away the ramps until the car is completely strapped-down and ready to depart. Similarly, when unloading I never touch any straps until the ramps are in place. |
EdwardBlume |
Sep 5 2014, 09:04 PM
Invest or make good blocks. I was able to secure my race car nicely with a tapered block with an eyebolt on it for tying to the wheel.
stugray |
Sep 5 2014, 10:01 PM
Invest or make good blocks. I was able to secure my race car nicely with a tapered block with an eyebolt on it for tying to the wheel. I use two of the harbor freight rubber kind. One on each side of a rear wheel bungeed together. I am guessing that last time I trailered mine, I probably left it in gear. I'll try to remember to take it out next time. |
Lo-Fi Version | Time is now: 6th May 2024 - 10:57 PM |
