FS: 6 conversion throttle cable & bracket - $50 shipped OBO |
Brian_Boss |
Aug 18 2014, 04:42 PM
Member Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
It is the type that does not use the pull rod/bellcrank. The bracket attaches to the bellhousing and the cable goes directly to the throttle crossbar.
Unknown manufacture. If it's homemade, they did a nice job. The bracket was cut with a die or on a shear, not cut out with a hack saw. The Gemo cable is in good shape with just a small chunk out of the outer plastic cover in one spot. It was working fine on my car. I am converting to the factory bellcrank arrangement while I have the motor out. |
Brian_Boss |
Aug 19 2014, 09:52 AM
JmuRiz |
Aug 19 2014, 11:43 AM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Oooooh, MFI (IMG:style_emoticons/default/biggrin.gif)
Great budget friendly solution. If I were closer to putting my engine in, I would be interested...but I need to hold off on parts until I am closer to install. |
Lo-Fi Version | Time is now: 9th June 2024 - 02:22 PM |
