It is the type that does not use the pull rod/bellcrank. The bracket attaches to the bellhousing and the cable goes directly to the throttle crossbar.
Unknown manufacture. If it's homemade, they did a nice job. The bracket was cut with a die or on a shear, not cut out with a hack saw. The Gemo cable is in good shape with just a small chunk out of the outer plastic cover in one spot.
It was working fine on my car. I am converting to the factory bellcrank arrangement while I have the motor out.
