Converting fuel tank to AN hose - How To |
patssle |
Aug 21 2014, 07:30 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I successfully found adapters that will fit on our fuel tanks, just wanted to share. No need to drill tap the tank - these fittings go on the existing threads. You can go to -6 or -8 AN. They come with an internal o-ring but I added thread sealant just for extra protection.
http://www.cbperformance.com/ProductDetail...roductCode=3288 http://www.cbperformance.com/ProductDetail...roductCode=3289 I plugged one with a cap and the other with a 90 degree AN to hose barb fitting if you don't want to use AN hose. |
Mike Bellis |
Aug 21 2014, 09:02 PM
I bought a pair of these too. -8 & -6 (supply & return) I'm happy there is a nice solution to rubber hoses on the tank. (IMG:style_emoticons/default/smile.gif)
JStroud |
Aug 21 2014, 09:19 PM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
That's funny, I just installed mine today, now all my fuel lines are -6 AN (IMG:style_emoticons/default/shades.gif)
Jeff |
Kansas 914 |
Aug 22 2014, 09:16 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
That's funny, I just installed mine today, now all my fuel lines are -6 AN (IMG:style_emoticons/default/shades.gif) Jeff Jeff, Do you have Chris' (Tangerine Racing) stainless steel lines? If so how did you transition to stainless? |
JStroud |
Aug 22 2014, 09:52 AM
That's funny, I just installed mine today, now all my fuel lines are -6 AN (IMG:style_emoticons/default/shades.gif) Jeff Jeff, Do you have Chris' (Tangerine Racing) stainless steel lines? If so how did you transition to stainless? I do have SS tunnel lines, I had McMark weld AN fitting on my SS lines. I believe Chris sells SS lines with AN fittings on them. Jeff |
Kansas 914 |
Aug 22 2014, 11:00 AM
That's funny, I just installed mine today, now all my fuel lines are -6 AN (IMG:style_emoticons/default/shades.gif) Jeff Jeff, Do you have Chris' (Tangerine Racing) stainless steel lines? If so how did you transition to stainless? I do have SS tunnel lines, I had McMark weld AN fitting on my SS lines. I believe Chris sells SS lines with AN fittings on them. Jeff Yes - Chris will sell weld AN fittings for $26 each - and shows them in the engine compartment ends. Did you get the AN fittings through the rubber stock grommet at the forward firewall or do something else? Thanks - hope to see you at RRC. |
VaccaRabite |
Aug 22 2014, 11:23 AM
En Garde! Group: Admin Posts: 13,448 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have seen clamp-on AN fittings too for those of us with earlier Tangerine SS fuel lines. I considered using them, but decided to just use hose clamps and keep a $20 problem from snowballing into a $100 problem in AN fittings, etc.
Zach |
patssle |
Aug 22 2014, 11:51 AM
I have seen clamp-on AN fittings too for those of us with earlier Tangerine SS fuel lines. I considered using them, but decided to just use hose clamps and keep a $20 problem from snowballing into a $100 problem in AN fittings, etc. Yeah AN fittings and hose can add up in cost. And after dealing with -12/-16 AN with my /6 conversion - I'm done with that crap. I stuck a stainless line (that I bought from Tangerine nearly 4 years ago) in the tunnel and bought the best rubber fuel hose (Gates Barricade) on the market. I'm running carbs and low fuel pressure anyways. |
Mike Bellis |
You can get AN tube adapters for $15 to fit 5/16, 3/8 & 1/2 hard line. I'm running them in my car. (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 27th May 2024 - 09:25 PM |
