Improving dash light brightness? |
Cuda911 |
Aug 22 2014, 12:21 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Hey all,
My one (and only) complaint with my 914 is that the dash lights are very faint and very hard to see at night (speedometer, etc.). Someone told me that brighter LED bulbs are available. Is that correct? If so, can someone provide me with: 1. What bulbs? 2. What source to buy them? 3. How many do I need? 4. Are they direct replacements (i.e. no other modifications need to install them) 5. To replace them, do I take out the 5 or so screws on the dash faceplate to access them? Thanks, guys! |
bluhun |
Aug 22 2014, 12:46 AM
Member Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
Hey all, My one (and only) complaint with my 914 is that the dash lights are very faint and very hard to see at night (speedometer, etc.). Someone told me that brighter LED bulbs are available. Is that correct? If so, can someone provide me with: 1. What bulbs? 2. What source to buy them? 3. How many do I need? 4. Are they direct replacements (i.e. no other modifications need to install them) 5. To replace them, do I take out the 5 or so screws on the dash faceplate to access them? Thanks, guys! The bulbs, designation BA7s-W, can be obtained from superbrightleds.com http://www.superbrightleds.com/cat/ba9s-ba7s/ I bought a pack of 15, which is plenty to replace all of the incandescent bulbs in the instrument cluster. They are direct plug-ins. Their is no need to remove any screws. Just pull the gauges directly out from the instrument cluster, remove the light receptacles from the rear of the gauges, remove the incandescent bulbs and replace with the LEDs. It makes a huge difference in illumination. |
Steve |
Mar 1 2021, 03:42 PM
914 Guru Group: Members Posts: 5,590 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Hey all, My one (and only) complaint with my 914 is that the dash lights are very faint and very hard to see at night (speedometer, etc.). Someone told me that brighter LED bulbs are available. Is that correct? If so, can someone provide me with: 1. What bulbs? 2. What source to buy them? 3. How many do I need? 4. Are they direct replacements (i.e. no other modifications need to install them) 5. To replace them, do I take out the 5 or so screws on the dash faceplate to access them? Thanks, guys! The bulbs, designation BA7s-W, can be obtained from superbrightleds.com http://www.superbrightleds.com/cat/ba9s-ba7s/ I bought a pack of 15, which is plenty to replace all of the incandescent bulbs in the instrument cluster. They are direct plug-ins. Their is no need to remove any screws. Just pull the gauges directly out from the instrument cluster, remove the light receptacles from the rear of the gauges, remove the incandescent bulbs and replace with the LEDs. It makes a huge difference in illumination. This is what i did for my car. The bulbs are direct replacement. I had to take off my steering wheel to pull the gauges. The only downside is the bulbs are not brightness adjustable, but the brightness is just right, so I wouldn't want to adjust them anyway. I only did the illumination bulbs. I left the stock bulbs for the idiot lights. I also have quite a stash of 914 parts, so I was able to change all the illumination bulb holders to the BA7 type. |
drem914 |
Mar 1 2021, 04:01 PM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
This is what i did for my car. The bulbs are direct replacement. I had to take off my steering wheel to pull the gauges. The only downside is the bulbs are not brightness adjustable, but the brightness is just right, so I wouldn't want to adjust them anyway. I only did the illumination bulbs. I left the stock bulbs for the idiot lights. I also have quite a stash of 914 parts, so I was able to change all the illumination bulb holders to the BA7 type. @Steve that's good to hear since the BA7 bulbs I found on amazon are supposed to be 200LM and the BA9 you swapped out for are listed at 150LM. The lower powered LEDS provided by carmagic and 914Ruber are listed for 50LM so I will be curious to see how the swap goes. I did them a few years back, it was a relatively easy swap, but not a big boost in brightness. |
drem914 |
Mar 19 2021, 10:24 PM
This is what i did for my car. The bulbs are direct replacement. I had to take off my steering wheel to pull the gauges. The only downside is the bulbs are not brightness adjustable, but the brightness is just right, so I wouldn't want to adjust them anyway. @Steve that's good to hear since the BA7 bulbs I found on amazon are supposed to be 200LM and the BA9 you swapped out for are listed at 150LM. The lower powered LEDS provided by carmagic and 914Ruber are listed for 50LM so I will be curious to see how the swap goes. I did them a few years back, it was a relatively easy swap, but not a big boost in brightness.I only did the illumination bulbs. I left the stock bulbs for the idiot lights. I also have quite a stash of 914 parts, so I was able to change all the illumination bulb holders to the BA7 type. Okay, so here is the result. (brightness with shop lights on in the garage directly overhead) and lights off except for running lights (Spokeworks LED front European style turn signals. They are bright enough to use them a driving lights.) I did not take a photo before. I should have to show the huge difference. I'll have to see if I have a before shot somewhere. 50lm vs 200lm, I would say so. I found these on amazon BA7 LED bulbs They come in a 10 pack for about $22. I will have to see how long they last. I was going to change the colored bulbs also, but so far what I have not seen any reason. The only downside to this is I now I cannot find one of my steering wheel screws.(IMG:style_emoticons/default/headbang.gif) I'll have to look during the day and see where it has run off to. |
Lo-Fi Version | Time is now: 21st May 2024 - 05:58 PM |
