Speedo cable, Boot wrong |
jeffdon |
Aug 23 2014, 02:53 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Dr Evil |
Aug 23 2014, 03:48 PM
Send me your transmission! Group: Members Posts: 22,999 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Jeff, I am not following you. You dont take it off. You screw the collar onto the speedo drive and then slide the rubber cuff over the collar. (IMG:style_emoticons/default/confused24.gif) That pic you have is correct. I have no idea what you had, but the pic is correct.
jeffdon |
Aug 23 2014, 06:25 PM
Jeff, I am not following you. You dont take it off. You screw the collar onto the speedo drive and then slide the rubber cuff over the collar. (IMG:style_emoticons/default/confused24.gif) That pic you have is correct. I have no idea what you had, but the pic is correct. Isn't this a boot that is to go over the tube in the fire wall? |
mepstein |
Aug 23 2014, 06:44 PM
914-6 GT in waiting Group: Members Posts: 19,272 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Jeff, I am not following you. You dont take it off. You screw the collar onto the speedo drive and then slide the rubber cuff over the collar. (IMG:style_emoticons/default/confused24.gif) That pic you have is correct. I have no idea what you had, but the pic is correct. Isn't this a boot that is to go over the tube in the fire wall? No. Read above. |
jeffdon |
Aug 23 2014, 08:05 PM
Jeff, I am not following you. You dont take it off. You screw the collar onto the speedo drive and then slide the rubber cuff over the collar. (IMG:style_emoticons/default/confused24.gif) That pic you have is correct. I have no idea what you had, but the pic is correct. Isn't this a boot that is to go over the tube in the fire wall? No. Read above. Ok, the cable has two boots. On that fits snugly over the end that screws to the speedo. The one in the picture fits well over the angle drive connection, but there is no boot for the tube where the cable goes into the tube in the firewall. That would need to be on the cable already, right? |
bluhun |
Aug 24 2014, 02:20 AM
Member Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
Jeff, I am not following you. You dont take it off. You screw the collar onto the speedo drive and then slide the rubber cuff over the collar. (IMG:style_emoticons/default/confused24.gif) That pic you have is correct. I have no idea what you had, but the pic is correct. Isn't this a boot that is to go over the tube in the fire wall? No. Read above. Ok, the cable has two boots. On that fits snugly over the end that screws to the speedo. The one in the picture fits well over the angle drive connection, but there is no boot for the tube where the cable goes into the tube in the firewall. That would need to be on the cable already, right? My observation directly above regarding your cable is incorrect. What you have is the boot that fits over the tube at the firewall, fitted backwards on the cable. What you appear to be missing is the smaller boot that seals at the speedometer angle drive. Sorry for the confusion. |
jeffdon |
Aug 24 2014, 06:41 AM
Jeff, I am not following you. You dont take it off. You screw the collar onto the speedo drive and then slide the rubber cuff over the collar. (IMG:style_emoticons/default/confused24.gif) That pic you have is correct. I have no idea what you had, but the pic is correct. Isn't this a boot that is to go over the tube in the fire wall? No. Read above. Ok, the cable has two boots. On that fits snugly over the end that screws to the speedo. The one in the picture fits well over the angle drive connection, but there is no boot for the tube where the cable goes into the tube in the firewall. That would need to be on the cable already, right? My observation directly above regarding your cable is incorrect. What you have is the boot that fits over the tube at the firewall, fitted backwards on the cable. What you appear to be missing is the smaller boot that seals at the speedometer angle drive. Sorry for the confusion. Thats what I thought. So there should be a total of three boots, right? |
bluhun |
Aug 24 2014, 09:14 PM
Jeff, I am not following you. You dont take it off. You screw the collar onto the speedo drive and then slide the rubber cuff over the collar. (IMG:style_emoticons/default/confused24.gif) That pic you have is correct. I have no idea what you had, but the pic is correct. Isn't this a boot that is to go over the tube in the fire wall? No. Read above. Ok, the cable has two boots. On that fits snugly over the end that screws to the speedo. The one in the picture fits well over the angle drive connection, but there is no boot for the tube where the cable goes into the tube in the firewall. That would need to be on the cable already, right? My observation directly above regarding your cable is incorrect. What you have is the boot that fits over the tube at the firewall, fitted backwards on the cable. What you appear to be missing is the smaller boot that seals at the speedometer angle drive. Sorry for the confusion. Thats what I thought. So there should be a total of three boots, right? No, just two boots. The smaller one fits over the speedo angle drive and the large one (the one in your picture) fits at the firewall. |
Lo-Fi Version | Time is now: 18th May 2024 - 12:10 AM |
