914-6 oil filler neck, Something has never been right on my car. |
ClayPerrine |
Aug 23 2014, 07:45 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Ok.. I have a question for those of you who have a six.
The filler neck on my six oil tank has never fit just right. It always seems a bit loose and floppy (no jokes here guys, I am serious). I was trying to replace the rubber connector between it and the tank, and it doesn't seem right either. And the last thing that has me questioning this is it always seems like I have too much oil in the tank when I fill it to the mark on the dipstick. The dipstick, tank and filler neck are all factory Porsche parts. The rubber boot does not reach the bulge in the filler neck, and the assembly has always looked wrong. My question... Is the filler neck supposed to slide into the tank opening, or does it just butt up against the tank? All the evidence I have with the oil level and the filler flopping around make me think it should slide into the opening on the tank. But it doesn't quite fit inside. |
Socalandy |
Aug 23 2014, 10:09 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
after a bit of digging I found some pics that may help. the rubber sleeve has a lip inside at the halfway point as a stop. do you have the clamp seen it these pictures?
Attached image(s) |
ClayPerrine |
Aug 24 2014, 06:09 AM
after a bit of digging I found some pics that may help. the rubber sleeve has a lip inside at the halfway point as a stop. do you have the clamp seen it these pictures? No, I have two small flathead screw clamps. Yours looks much more solid than mine with that clamp. I am going to check with my parts supplier. Where did you get the clamp? |
Lo-Fi Version | Time is now: 18th May 2024 - 06:01 PM |
