914-6 oil filler neck, Something has never been right on my car. |
ClayPerrine |
Aug 23 2014, 07:45 PM
Life's been good to me so far..... Group: Admin Posts: 15,484 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Ok.. I have a question for those of you who have a six.
The filler neck on my six oil tank has never fit just right. It always seems a bit loose and floppy (no jokes here guys, I am serious). I was trying to replace the rubber connector between it and the tank, and it doesn't seem right either. And the last thing that has me questioning this is it always seems like I have too much oil in the tank when I fill it to the mark on the dipstick. The dipstick, tank and filler neck are all factory Porsche parts. The rubber boot does not reach the bulge in the filler neck, and the assembly has always looked wrong. My question... Is the filler neck supposed to slide into the tank opening, or does it just butt up against the tank? All the evidence I have with the oil level and the filler flopping around make me think it should slide into the opening on the tank. But it doesn't quite fit inside. |
rgalla9146 |
Aug 9 2021, 08:30 AM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
OEM clamp and rubber collar
The clamp is stamped 'NORMA schellen' 54 (mm) which is the diameter The width is 25mm or 1" Attached thumbnail(s) |
raynekat |
Aug 9 2021, 03:33 PM
Advanced Member Group: Members Posts: 2,159 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 26th May 2024 - 05:58 PM |
