Your current TYPE IV set up, Tell me what you have and what you think about it |
Hine62 |
Aug 25 2014, 10:38 AM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
I'd like to know what some of the members are running for a type iv. Please answer the following questions:
1. What is the stroke, bore, and CC's of the engine? 2. If the engine is stroked over 71mm what case work was needed? 3. What cam are you running? 4. If using carbs/EFI, what is the setup? 5. What's the HP, or do you feel the engine has good torque/HP for the setup you have? 6. Comments on anything else... Hine62 |
crash914 |
Aug 25 2014, 10:53 AM
its a mystery to me Group: Members Posts: 1,826 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
103 bore, 80mm stroke, reduced base circle cam, relieved case and big end of the rods...had to machine case for the cylinders, ordered heads to fit the larger cylinders..fuel injected megasquirt...horsepower? no idea, but pulls a lot better than stock! 150+ or so..torque to match. I set this up to be a torque monster..so far it is. I need a lot more tire as I light them up way too easily. it makes autocross a lot of fun.
Lo-Fi Version | Time is now: 17th May 2024 - 03:38 AM |
