Your current TYPE IV set up, Tell me what you have and what you think about it |
Hine62 |
Aug 25 2014, 10:38 AM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
I'd like to know what some of the members are running for a type iv. Please answer the following questions:
1. What is the stroke, bore, and CC's of the engine? 2. If the engine is stroked over 71mm what case work was needed? 3. What cam are you running? 4. If using carbs/EFI, what is the setup? 5. What's the HP, or do you feel the engine has good torque/HP for the setup you have? 6. Comments on anything else... Hine62 |
colingreene |
Aug 25 2014, 12:04 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
mines a 94mmx78mm
makes it a 2258 we did clear the case slightly but it was not a huge deal with Jorges rods. Running dual webber 40 IDF carbs Not sure about the hp but i can tell you its heavy to move around on the cart in my garage, hopefully ill know more soon! |
Lo-Fi Version | Time is now: 19th May 2024 - 05:43 AM |
