Your current TYPE IV set up, Tell me what you have and what you think about it |
Hine62 |
Aug 25 2014, 10:38 AM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
I'd like to know what some of the members are running for a type iv. Please answer the following questions:
1. What is the stroke, bore, and CC's of the engine? 2. If the engine is stroked over 71mm what case work was needed? 3. What cam are you running? 4. If using carbs/EFI, what is the setup? 5. What's the HP, or do you feel the engine has good torque/HP for the setup you have? 6. Comments on anything else... Hine62 |
Elliot Cannon |
Aug 25 2014, 04:00 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
FAT Perfromance built. 76 crank, 96 pistons, 44idf Webers, Euro Headers, ceramic valve lifters. 147 HP at 5,500 RPM.
Lo-Fi Version | Time is now: 18th May 2024 - 06:27 PM |
