Your current TYPE IV set up, Tell me what you have and what you think about it |
Hine62 |
Aug 25 2014, 10:38 AM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
I'd like to know what some of the members are running for a type iv. Please answer the following questions:
1. What is the stroke, bore, and CC's of the engine? 2. If the engine is stroked over 71mm what case work was needed? 3. What cam are you running? 4. If using carbs/EFI, what is the setup? 5. What's the HP, or do you feel the engine has good torque/HP for the setup you have? 6. Comments on anything else... Hine62 |
Bills914-4 |
Aug 25 2014, 06:44 PM
Member Group: Members Posts: 310 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
My new rebuild I just finished,(still putting together megasquirt 2xtra ignition/8 plugs)
84c x 103 ( 2800cc ) 5.7 h-beam rods moly coated main,rod & cam bearings new pauter dual pattern cam ( 1" base circle ) 1.48 pauter bushed roller tip rockers dual taper cromoly pushrods old school aria's forged pistons , ceramic coated tops & moly coated skirts 48x38 11 to 1 cr. heads with ceramic coated chambers & valve faces CB's vw650 springs with BP's titanium retainers & modified comp-cams lash caps twin spark plug conversion 1 7/8 cfr tangerine exaust CB's 48mm dual throttle bodies & efi (eventually megasquirt 2xtra efi ) custom dry-sump oil system 11 lbs. flywheel, KEP stage II p.p. & custom clutchnet disc cheers Bill D. |
saigon71 |
Aug 25 2014, 06:58 PM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My new rebuild I just finished,(still putting together megasquirt 2xtra ignition/8 plugs) 84c x 103 ( 2800cc ) 5.7 h-beam rods moly coated main,rod & cam bearings new pauter dual pattern cam ( 1" base circle ) 1.48 pauter bushed roller tip rockers dual taper cromoly pushrods old school aria's forged pistons , ceramic coated tops & moly coated skirts 48x38 11 to 1 cr. heads with ceramic coated chambers & valve faces CB's vw650 springs with BP's titanium retainers & modified comp-cams lash caps twin spark plug conversion 1 7/8 cfr tangerine exaust CB's 48mm dual throttle bodies & efi (eventually megasquirt 2xtra efi ) custom dry-sump oil system 11 lbs. flywheel, KEP stage II p.p. & custom clutchnet disc cheers Bill D. Damn, that's an awesome type 4! I look forward to seeing the dyno chart on this one. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 03:26 AM |
