Your current TYPE IV set up, Tell me what you have and what you think about it |
Hine62 |
Aug 25 2014, 10:38 AM
Member Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
I'd like to know what some of the members are running for a type iv. Please answer the following questions:
1. What is the stroke, bore, and CC's of the engine? 2. If the engine is stroked over 71mm what case work was needed? 3. What cam are you running? 4. If using carbs/EFI, what is the setup? 5. What's the HP, or do you feel the engine has good torque/HP for the setup you have? 6. Comments on anything else... Hine62 |
Dion |
Aug 27 2014, 11:04 AM
RN Group: Members Posts: 2,765 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Hello,
"2056" 76 case,stock crank, "Mild" FAT cam, Lift 413,Duration 258. works well with fuel inj. Web solid lifters 96mm JE pistons 9.5:1 compression,71mm AA cylinders CIS Fuel inj. (Rabbit/924 stuff), 009 distributor with compufire Runs well, torque is there thru upper rev range Sweet spot around 3500-4200rpm ,feels that way anyhow. On paper around 120HP ?? Need to dyno. Extra oil cooler with fan next to tranny. Oil temps 190-210*F Quite pleased. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:38 AM |
