73 Engine bar distance between bolt holes |
doug_b_928 |
Aug 26 2014, 08:53 PM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I'd greatly appreciate it if someone could please post the distance between the bolt holes center to center on a 73 engine bar (not sure if it's the same for all years). I need the data to compare to the homemade one that was installed by the DAPO. This will help me to determine if the bar I have was created due to a fitment issue (body twist) or for some other reason that is beyond my imagination.
doug_b_928 |
Aug 27 2014, 10:18 AM
Rough measurement suggests that mine is 41 7/8, so 1/4" wider. If this is a true difference, is there any adjustment in the plates that hold the bolts, or would this be the reason for the homemade engine bar?
Thanks for additional info on the bolts and washer. Cn2800, if you could check the size of the bolt (length, diameter and threads), that would be great! |
Lo-Fi Version | Time is now: 17th May 2024 - 09:57 AM |
