73 Engine bar distance between bolt holes |
doug_b_928 |
Aug 26 2014, 08:53 PM
I'd greatly appreciate it if someone could please post the distance between the bolt holes center to center on a 73 engine bar (not sure if it's the same for all years). I need the data to compare to the homemade one that was installed by the DAPO. This will help me to determine if the bar I have was created due to a fitment issue (body twist) or for some other reason that is beyond my imagination.
maf914 |
Aug 28 2014, 06:47 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Make sure you get the correct style engine bar for your car, either late side shifter or early tail shifter, as they are not the same.
Lo-Fi Version | Time is now: 17th May 2024 - 07:15 AM |
