Which comes first: Straightening the tub or structural rust repair? |
doug_b_928 |
Aug 28 2014, 06:16 AM
I've been disassembling my car and getting a better sense of what happened to it before my ownership. I think the car was hit on the left rear corner. It doesn't appear that it crumpled much at all. In fact, the left taillight assembly was re-used (the black plastic on the end is missing a 1 cm piece and there's a crack in the middle of the black plastic on the back). There's also a really bad bondo repair about the diameter of an average hand by the tailight. So I don't think much crumple-type of damage was done. But, that hit must have somehow twisted the chassis by either pushing the left rear down and/or pushing the right rear up. There is a big difference in height left to right when looking at the rear end (like 1 -1.5"). The suspension ear on the right is 4mm higher than the one on the left. The latter might even be within factory spec, no? Also, the distance between the trunk channels on the rear fenders is within spec for the front half, but the back half progressively narrows to being 1.5cm too narrow.
The longs, rockers, firewall and hell hole are shot and the door gaps by the door handles are too big (8-9mm). So, I'm wondering, (aside from the option of scrapping it), do I get the chassis straightened before metal surgery, or after surgery on the main structural parts? I could see the former tearing the car apart, and the latter creating imperfections in the newly repaired work. |
doug_b_928 |
Aug 29 2014, 04:05 PM
Steve, did you measure the suspension points in the underbody diagram? The one where you measure from both front points to each rear suspension point should tell you if it's square. I need to redo those ones now that I have it on the bench but have to wait for my helper (aka wifey) to be available. In terms of level, the way I'm doing it is to have it on a bench that's true (my floor isn't level), and measure up from that.
Lo-Fi Version | Time is now: 13th May 2024 - 06:12 PM |
