Which comes first: Straightening the tub or structural rust repair? |
doug_b_928 |
Aug 28 2014, 06:16 AM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I've been disassembling my car and getting a better sense of what happened to it before my ownership. I think the car was hit on the left rear corner. It doesn't appear that it crumpled much at all. In fact, the left taillight assembly was re-used (the black plastic on the end is missing a 1 cm piece and there's a crack in the middle of the black plastic on the back). There's also a really bad bondo repair about the diameter of an average hand by the tailight. So I don't think much crumple-type of damage was done. But, that hit must have somehow twisted the chassis by either pushing the left rear down and/or pushing the right rear up. There is a big difference in height left to right when looking at the rear end (like 1 -1.5"). The suspension ear on the right is 4mm higher than the one on the left. The latter might even be within factory spec, no? Also, the distance between the trunk channels on the rear fenders is within spec for the front half, but the back half progressively narrows to being 1.5cm too narrow.
The longs, rockers, firewall and hell hole are shot and the door gaps by the door handles are too big (8-9mm). So, I'm wondering, (aside from the option of scrapping it), do I get the chassis straightened before metal surgery, or after surgery on the main structural parts? I could see the former tearing the car apart, and the latter creating imperfections in the newly repaired work. |
doug_b_928 |
Aug 31 2014, 02:16 PM
Rick, I'm going to take some good pics of the rust and send to you but will wait until I'm finished dismantling so that you can get as clear of a picture as possible.
In the meantime, I've been thinking, would it make sense to put it on the cellete, pull it into submission, then put it back on my bench and make fixtures/jigs for the rear suspension points and shock towers, then do the metal surgery? That way there would be minimal days needed for renting the fixtures. |
Lo-Fi Version | Time is now: 14th May 2024 - 12:31 PM |
