Which comes first: Straightening the tub or structural rust repair? |
doug_b_928 |
Aug 28 2014, 06:16 AM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I've been disassembling my car and getting a better sense of what happened to it before my ownership. I think the car was hit on the left rear corner. It doesn't appear that it crumpled much at all. In fact, the left taillight assembly was re-used (the black plastic on the end is missing a 1 cm piece and there's a crack in the middle of the black plastic on the back). There's also a really bad bondo repair about the diameter of an average hand by the tailight. So I don't think much crumple-type of damage was done. But, that hit must have somehow twisted the chassis by either pushing the left rear down and/or pushing the right rear up. There is a big difference in height left to right when looking at the rear end (like 1 -1.5"). The suspension ear on the right is 4mm higher than the one on the left. The latter might even be within factory spec, no? Also, the distance between the trunk channels on the rear fenders is within spec for the front half, but the back half progressively narrows to being 1.5cm too narrow.
The longs, rockers, firewall and hell hole are shot and the door gaps by the door handles are too big (8-9mm). So, I'm wondering, (aside from the option of scrapping it), do I get the chassis straightened before metal surgery, or after surgery on the main structural parts? I could see the former tearing the car apart, and the latter creating imperfections in the newly repaired work. |
rick 918-S |
Aug 31 2014, 08:47 PM
Hey nice rack! -Celette Group: Members Posts: 20,455 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
As soft as that car is there is no way it could be pulled, then removed from the bench and placed on another bench without the car falling in half. If I were to get involved I wouldn't bother mounting the car without the full expectation that the chassis would be welding while the car sits on the fixtures.
Here's an example why: You have two problems here. The rear of the car is twisted, the longs are rusted. A down force pull and a push up will very likely lead to the rusted chassis to become very weak. Weaker that it is now. As soon as it is released from the fixtures and lifted off it will start to sag. The door opening spread when lifting and close when set back on your fixture. Once this happens how do you plan on re-establishing data points? Have you ever heard a car creak and pop during pulling? Now try pulling a rusted car and add a crunching and tearing sound.... (IMG:style_emoticons/default/unsure.gif) Two problems, one solution. |
Lo-Fi Version | Time is now: 13th May 2024 - 05:37 PM |
