Exhaust for stock 1.7, anything definitive? |
Always Looking |
Jan 25 2005, 01:11 PM
Member Group: Members Posts: 194 Joined: 9-December 04 From: Orange, CA Member No.: 3,246 |
I know there is a general consensus on Bilsteins for the suspension. Is there a similar consensus for exhaust? I have a stock 1972 1.7 FI. Now I have a monza four tip exhaust of unknown quality (it seems too loud) with three of the four chrome tips cut off (from PO). I am pre-smog and use the car as a weekend driver (and hopefully an autoX or two per year).
(IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
VegasRacer |
Jan 25 2005, 01:31 PM
ELVIRA Group: Benefactors Posts: 8,497 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Bursch
balthazar |
Jan 26 2005, 12:44 PM
P-car junkie Group: Members Posts: 161 Joined: 23-March 03 From: Arvada, Colorado Member No.: 464 |
You should install this exaust!
(from the 914 1.7l turbo thread) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) http://wwwhttp://www.914world.com/bbs2/ind...=ST&f=2&t=17090 Attached image(s) |
Root_Werks |
Jan 26 2005, 12:59 PM
Village Idiot Group: Members Posts: 8,312 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
(IMG:http://www.914world.com/bbs2/html/emoticons/drooley.gif) that looks pretty dang cool! Simple too! |
balthazar |
Jan 28 2005, 02:32 PM
I am attempting to copy this design for my 1.7 Just finished doing a side shifter swap on the transaxle. Once the Mega Squirt unit is installed and tuned, I get to start the fun!!!
(IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
TonyAKAVW |
Jan 28 2005, 02:40 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
What about the compression of the non-73 1.7 engines? I was all convinced that I wanted to do the same thing to my 1.7 until someone pointed out that unless its a 73 1.7 it has higher compression ratio. Is this really critical? Otherwise I was planning on turboing my 75 1.8 engine which has low compression..
-Tony |
jd74914 |
Jan 28 2005, 02:47 PM
it all depends on the amount of boost. if its wild lower compression might be good (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) really simple exhaust design, i want to try a type4 turbo some day |
balthazar |
Jan 28 2005, 02:58 PM
8.2/1 CR is not THAT high. It's like jd74914 was saying, as long as you keep the boost down, it's not that critical. I will only be looking for 8-10psi boost. The other thing is that I will be running Mega Squirt. The brain will take an input from a knock sensor...MUHAHAHAHA (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:19 PM |
