FS: Gauges (tach/fuel-temp/CHT/volt/oil pres) |
patssle |
Aug 30 2014, 12:42 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Tach 914.641.302.12 - worked when pulled: $50 + shipping
SOLD Fuel/Temp 914.641.101.50 - fuel worked, never used temp: $50 + shipping SOLD Cylinder Head Temp (works with spark plug temp sender VDO-323701) - worked when pulled: $15 + shipping Cels Oil/Water Temp 310.274/82/4 - unknown working condition never used: $5 + shipping SOLD Oil Pressure PSI 350104 - unknown working condition never used: $10 + shipping SOLD Volt Meter 332.304/15/4 - works: $10 + shipping |
patssle |
Aug 30 2014, 01:42 PM
I also have a dual oil pressure sender (idiot light plus gauge). It's 0-5 bar so should work with the gauge listed above. Contact number is 30/2. Also not used/tested - don't know if it works and sold as-is. Can do gauge/sender for $20 plus shipping.
jvmarino |
Aug 30 2014, 01:57 PM
Member Group: Members Posts: 80 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
I also have a dual oil pressure sender (idiot light plus gauge). It's 0-5 bar so should work with the gauge listed above. Contact number is 30/2. Also not used/tested - don't know if it works and sold as-is. Can do gauge/sender for $20 plus shipping. I will take the oil pressure gauge with sender if still available. Jim |
dangrouche |
Aug 30 2014, 06:49 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
I will take the CHT gauge please; my zip is 94014
2nd in line please if jvmarino declines purchase of oil sender and oil gauge pressure gauge for $20 plus shipping |
type47 |
Aug 31 2014, 05:32 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
PM sent for fuel gauge with temp
patssle |
Aug 31 2014, 07:03 PM
Tach, volt meter, and cels oil temp gauges still available. Rest are sold.
funk |
Aug 31 2014, 08:27 PM
Member Group: Members Posts: 100 Joined: 23-June 14 From: sandpoint idaho Member No.: 17,531 Region Association: Pacific Northwest |
i will buy the voltage guage!!
Lo-Fi Version | Time is now: 5th May 2024 - 04:59 PM |
