FS: Gauges (tach/fuel-temp/CHT/volt/oil pres) |
patssle |
Aug 30 2014, 12:42 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Tach 914.641.302.12 - worked when pulled: $50 + shipping
SOLD Fuel/Temp 914.641.101.50 - fuel worked, never used temp: $50 + shipping SOLD Cylinder Head Temp (works with spark plug temp sender VDO-323701) - worked when pulled: $15 + shipping Cels Oil/Water Temp 310.274/82/4 - unknown working condition never used: $5 + shipping SOLD Oil Pressure PSI 350104 - unknown working condition never used: $10 + shipping SOLD Volt Meter 332.304/15/4 - works: $10 + shipping |
patssle |
Aug 30 2014, 01:42 PM
I also have a dual oil pressure sender (idiot light plus gauge). It's 0-5 bar so should work with the gauge listed above. Contact number is 30/2. Also not used/tested - don't know if it works and sold as-is. Can do gauge/sender for $20 plus shipping.
jvmarino |
Aug 30 2014, 01:57 PM
Member Group: Members Posts: 81 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
I also have a dual oil pressure sender (idiot light plus gauge). It's 0-5 bar so should work with the gauge listed above. Contact number is 30/2. Also not used/tested - don't know if it works and sold as-is. Can do gauge/sender for $20 plus shipping. I will take the oil pressure gauge with sender if still available. Jim |
Lo-Fi Version | Time is now: 18th May 2024 - 05:48 PM |
