Muffler shield |
Muffler shield |
nein14 |
Aug 31 2014, 10:25 AM
Senior Member Group: Members Posts: 838 Joined: 6-February 03 From: USA Member No.: 262 |
Trying to remove my muffler shield I cut the bracket on each end
What else is holding it? |
ThePaintedMan |
Aug 31 2014, 10:55 AM
Couple of bolts as well.
rgalla9146 |
Aug 31 2014, 10:56 AM
Advanced Member Group: Members Posts: 4,554 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The middle ones
Pretty sure there are six; two,two and two On early cars or sixes they are held by sheet metal screws in the trunk. |
McMark |
Aug 31 2014, 11:11 AM
The middle ones Pretty sure there are six; two,two and two On early cars or sixes they are held by sheet metal screws in the trunk. (IMG:style_emoticons/default/thumb3d.gif) |
nein14 |
Aug 31 2014, 11:38 AM
The middle ones Pretty sure there are six; two,two and two On early cars or sixes they are held by sheet metal screws in the trunk. (IMG:style_emoticons/default/thumb3d.gif) Looked in the trunk no screws or bolts I just see what looks like spot welds between The tailight and the lock on each side the car is a 73 |
peteyd |
Aug 31 2014, 06:17 PM
Senior Member Group: Members Posts: 707 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
there are tabs spotwelded in the center as well. I removed one for a customer a while back and had to use a zip wheel cutting from inside the truck.
No nuts or bolts were holding this one on. Pete |
worn |
Aug 31 2014, 06:33 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Elliot Cannon |
Aug 31 2014, 06:38 PM
Paint the underside of the trunk with VHT high-temp paint. It works great as an insulator and will help keep the trunk cooler. I remember reading about a race team years ago that painted the fire wall of the car with VHT and it lowered the cockpit temp. 15 degrees. (IMG:style_emoticons/default/biggrin.gif)
barefoot |
Sep 3 2014, 04:29 PM
Senior Member Group: Members Posts: 1,275 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
The middle ones Pretty sure there are six; two,two and two On early cars or sixes they are held by sheet metal screws in the trunk. Confirmed, six spacer tabs with 2 spot welds each. I replaced the trunk rear panel and was able to cut away the spot welds and save the heat shield. Mine is now pop riveted with SS rivets |
Sep 3 2014, 04:49 PM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
- Early cars, 6 tabs with sheet metal screws - Later cars, 6 tabs with spot-welds (IMG:style_emoticons/default/smile.gif) |
nein14 |
Sep 3 2014, 06:08 PM
Thanks Guys for all the insight got it off (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 07:31 PM |
