Penetrating oil test |
puffinator |
Aug 31 2014, 01:47 PM
Member Group: Members Posts: 193 Joined: 6-August 13 From: Annapolis, MD Member No.: 16,218 Region Association: MidAtlantic Region |
I got this via another car guy forum.
For All of you Mechanic's and Self doer’s out there. Penetrating Oil - interesting This was in one of the Military Vehicle Club newsletters Here is an interesting article submitted by Bob Muller for our members consideration Penetrating Oils Recently “Machinist Workshop Magazine” did a test on penetrating oils. Using nuts and bolts that they ‘scientifically rusted’ to a uniform degree by soaking in salt water, they then tested the break-out torque required to loosen the nuts. They treated the nuts with a variety of penetrants and measured the torque required to loosen them. This is what they came up with: Nothing: 516 lbs WD-40: 238 lbs; PB Blaster: 214 lbs; Liquid Wrench: 127 lbs, Kano Kroil: 106 lbs (ATF)/Acetone mix (50/50): 50 lbs. This last “shop brew” of 50% automatic transmission fluid and 50% acetone appears to beat out the commercially prepared products costing far more. |
Jake Raby |
Sep 1 2014, 01:38 PM
They should have tried melted paraffin, too.. That along with the acetone/ ATF is what I've always used. Three years ago I started working on freeing up the impellers of a very old hydro electric power plant, and nothing would work except the ATF/ Acetone trick.
After 3 months we got it back up and running again. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:29 PM |
