Bump Steer Kit, I guess PO installed one |
Jetsetsurfshop |
Aug 31 2014, 04:38 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
These spacers are not factory, correct? I just bought a Bump steer kit and found this when I removed the shield. I've had that shield off 10 times and didn't take note. Duh
Attached thumbnail(s) |
jim_hoyland |
Aug 31 2014, 08:46 PM
Get that VIN ? Group: Members Posts: 9,265 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
I the car lowered ?
Jetsetsurfshop |
Aug 31 2014, 09:15 PM
It is lowered. Behaves badly under hard braking on the track. Bought a bump steer kit to help, then discovered there was one already there. Also noticed that the drivers shock has no travel, passenger one does, although limited. Ideas?
Mike Bellis |
Aug 31 2014, 09:25 PM
Has the car been corner balanced? If not, do so.
Andyrew |
Sep 1 2014, 09:16 AM
It is lowered. Behaves badly under hard braking on the track. Bought a bump steer kit to help, then discovered there was one already there. Also noticed that the drivers shock has no travel, passenger one does, although limited. Ideas? If the shock has no travel, then its either adjusted to heavy or something is wrong with it. Pull both and inspect. If adjustable adjust them similar. What is your suspension setup? |
Jetsetsurfshop |
Sep 1 2014, 11:17 AM
Have attempted to corner balance. Right front corner (if I remember correctly) was a little light.
As far as the shock go, I think theres something wrong with it. I have 1976 911 struts with Bilstens. They were new two years ago. I'm going to put it and inspect. There is some oil seeping from out of the top. I wonder If I added to much oil in there when I installed it. We also have it adjusted pretty low. At tracks like Homestead it amazing, at Sebring, not so much. I don't thing its to low. Heres a pic. Attached thumbnail(s) |
ChrisFoley |
Sep 2 2014, 08:17 AM
I am Tangerine Racing Group: Members Posts: 7,911 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Yes it's too low.
SirAndy |
Sep 2 2014, 11:16 AM
Resident German Group: Admin Posts: 41,607 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Btw., i really hate those rack spacer bump steer kits.
I prefer the extensions that go on the tie rod ends and leave the steering rack in it's original location. (IMG:style_emoticons/default/smile.gif) |
ChrisFoley |
Sep 2 2014, 11:30 AM
Btw., i really hate those rack spacer bump steer kits. I prefer the extensions that go on the tie rod ends and leave the steering rack in it's original location. (IMG:style_emoticons/default/smile.gif) That would require actually measuring the bump steer. (IMG:style_emoticons/default/unsure.gif) |
SirAndy |
Sep 2 2014, 11:44 AM
Btw., i really hate those rack spacer bump steer kits. I prefer the extensions that go on the tie rod ends and leave the steering rack in it's original location. (IMG:style_emoticons/default/smile.gif) I've had pretty good results with just eyeballing it. (IMG:style_emoticons/default/biggrin.gif) http://www.tarett.com/items/911-products/9...rbsk-detail.htm (IMG:http://www.914world.com/bbs2/uploads_offsite/www.tarett.com-179-1409679863.1.jpg) |
Jetsetsurfshop |
Sep 2 2014, 01:23 PM
I have no idea what bump steer looks or feels like. Almost all my track days are at Sebring. I'm I getting bump steer or is it more like bumping and steering? (IMG:style_emoticons/default/huh.gif)
I have access to an alignment rack, Should I drive my car up on it and see if the tie rods are level? I guess the real question is how to measure bump steer? Thanks as always... |
Jetsetsurfshop |
Sep 2 2014, 01:30 PM
Yes it's too low. Different pic without the right side tires not loaded up. Still think its to low? Attached thumbnail(s) |
Lo-Fi Version | Time is now: 29th April 2024 - 07:27 PM |
