Bump Steer Kit, I guess PO installed one |
Jetsetsurfshop |
Aug 31 2014, 04:38 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
These spacers are not factory, correct? I just bought a Bump steer kit and found this when I removed the shield. I've had that shield off 10 times and didn't take note. Duh
Attached thumbnail(s) |
Jetsetsurfshop |
Aug 31 2014, 09:15 PM
It is lowered. Behaves badly under hard braking on the track. Bought a bump steer kit to help, then discovered there was one already there. Also noticed that the drivers shock has no travel, passenger one does, although limited. Ideas?
Andyrew |
Sep 1 2014, 09:16 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
It is lowered. Behaves badly under hard braking on the track. Bought a bump steer kit to help, then discovered there was one already there. Also noticed that the drivers shock has no travel, passenger one does, although limited. Ideas? If the shock has no travel, then its either adjusted to heavy or something is wrong with it. Pull both and inspect. If adjustable adjust them similar. What is your suspension setup? |
Lo-Fi Version | Time is now: 16th May 2024 - 07:26 PM |
