twin plug 2.6 litre, any info? |
vinniedatorch |
Sep 5 2014, 10:33 PM
Newbie Group: Members Posts: 40 Joined: 12-January 13 From: Lakewood Ca. Member No.: 15,358 Region Association: Southern California |
Just picked up a twin plugged 2.6 litre and wondering if anyone has experience with this ignition setup and distributor config? wondering if I want to set it up as a single plug per cylinder for street car or if? Pro's and con's. any input ?
campbellcj |
Sep 5 2014, 11:04 PM
I can't Re Member Group: Members Posts: 4,545 Joined: 26-December 02 From: Agoura, CA Member No.: 21 Region Association: Southern California |
I assume you mean a six? What distributor and coil/CDI setup does it have? Why would you want to switch back to a single-plug? The twin-plug is highly desirable if you are over a certain compression ratio. Do you know the C/R and do you know if it is set up to run race fuel, or regular pump fuel?
I do have a twin-plug 2.7 so will be glad to share my limited knowledge if I can help... |
vinniedatorch |
Sep 6 2014, 12:41 PM
I assume you mean a six? What distributor and coil/CDI setup does it have? Why would you want to switch back to a single-plug? The twin-plug is highly desirable if you are over a certain compression ratio. Do you know the C/R and do you know if it is set up to run race fuel, or regular pump fuel? I do have a twin-plug 2.7 so will be glad to share my limited knowledge if I can help... It's a type 4 2.6 with twin plugs. Basket case w/ new components, being assembled. Distributor is a Nissan with an 8 plug cap, dual Bosch coils. Hoping for info as guidance on choosing proper compression, want to run on a street able 912 coupe SWB. Pump gas. As I said in prices when I bought it and trying to figure what direction to go with it. I know I want a beast with some longevity, so maybe limit compression, maximize tourque and hope for something I can get some miles out of |
Lo-Fi Version | Time is now: 20th May 2024 - 12:17 AM |
