How Do You Re-Attach the Rear Trunk Torsion Bars |
7TPorsh |
Sep 10 2014, 11:16 AM
The PO unhooked the rear torsion bars for the trunk. Nothing holds the trunk up when open....damn that thing is heavy.
The bars are still bolted in the car but the ends are not wrapped on the trunk supports/hinges. I don't really want to add struts; the stock system should work fine for me if set up right. Is there an established process? |
Spoke |
Sep 10 2014, 11:19 AM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Get a socket extension, 3/8 inch, and put the end on the torsion bar and carefully pull it down to get below the roller.
Use heavy gloves and goggles cause those springs can launch the extension. Others may chime in with a better/safer method... |
TheCabinetmaker |
Sep 10 2014, 11:31 AM
What he meant to say was, use a10mm deep socket on an extension.
914_teener |
Sep 10 2014, 12:11 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I would have a helper on this one having done it.
You need new metal or plastic rollers if they are not there. You can get the metal ones at the Bird. Other than that a pretty easy ......... |
mskala |
Sep 10 2014, 12:58 PM
If you have access to a welder, you can use a straight piece of stock
with 2 'pins' welded on, about an inch high, just enough space between them for the torsion bar diameter. I could post a pic later. |
bandjoey |
Sep 10 2014, 01:14 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Isn't there a Pelican pictorial on this?
Jeffs9146 |
Sep 10 2014, 01:50 PM
7TPorsh |
Sep 10 2014, 02:11 PM
I bumped the old thread for the pics...http://www.914world.com/bbs2/index.php?showtopic=9827
mskala |
Sep 10 2014, 06:30 PM
ClayPerrine |
Sep 10 2014, 06:43 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Here is a thread on putting the torsion bars back on....
Torsion Bar install BTW... the notched crescent wrench was invented in 1977 by the late Wes Hildreth. |
boxstr |
Sep 10 2014, 08:36 PM
What about rear trunk shox?
Craig at CAMP |
Sep 11 2014, 08:54 AM
buck toenges |
Sep 11 2014, 02:16 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
The notched crescent wrench is the ticket. have a helper and read up the pelican thread. Just take it easy and keep your fingers out of the way.
mtndawg |
Sep 11 2014, 02:22 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
Agreed on the crescent wrench. It works great. It's a (very careful) 2 person job...again, be careful or you'll take a body part off if you slip. It should be very uneventful when done correctly.
monkeyboy |
Sep 11 2014, 02:41 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I can show you some broken thumb pics from when mine was reinstalled... Trunk shocks are the bomb.
Those stupid torsion bars cause undue stress on the pivots as well. |
ClayPerrine |
Sep 11 2014, 05:21 PM
I can show you some broken thumb pics from when mine was reinstalled... Trunk shocks are the bomb. Those stupid torsion bars cause undue stress on the pivots as well. If you regularly lubricate the pivot bushings, then the stress is no more than any other part. I have two 914s with the torsion bars. I keep them lubed so they don't make noise, and the only time I replaced the pivots is when I first got the cars, 28 years ago. |
ruby914 |
Sep 12 2014, 01:35 AM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
I can show you some broken thumb pics from when mine was reinstalled... Trunk shocks are the bomb. Those stupid torsion bars cause undue stress on the pivots as well. If you regularly lubricate the pivot bushings, then the stress is no more than any other part. I have two 914s with the torsion bars. I keep them lubed so they don't make noise, and the only time I replaced the pivots is when I first got the cars, 28 years ago. This is what I made. It worked well for me. Don't need it now. Stop by, If your in the hood. Or, PM me your address and I will send it up. Attached image(s) |
Lo-Fi Version | Time is now: 19th May 2024 - 10:08 AM |
