Alternate fuel pump, Holley 12-920/927 |
cwpeden |
Sep 11 2014, 07:46 AM
The last of my stock 73 2.0L fuel pumps gave up the ghost this week. Leaking out the electrical connector. So i'm looking for an alternate.
I would like to replace it with an off the shelf pump that can be gotten almost anywhere. First I've come up with is the Holley 12-920 or 927. Anyone using these? If so, suggestions on plumbing? |
Cap'n Krusty |
Sep 11 2014, 08:50 AM
Either will be fine, unless you want your car to actually run. Pressure's 1/2 to 2/3 of what is necessary just to pressurize the system. The OE pumps put out upwards of 45 psi and operate at about 30. Just go with the later Bosch pump, sold at NAPA stores. Fittment is for 1975-1979 VW beetles and 1976-1991 bus/vanagons.
The Cap'n |
cwpeden |
Sep 11 2014, 09:35 AM
That's what I thought. Couldn't figure out how the Holley pump could be both 15 and 45 psi?
ClayPerrine |
Sep 11 2014, 10:57 AM
Life's been good to me so far..... Group: Admin Posts: 15,443 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There is a replacement after market pump:
Airtex E8445. It produces the same pressure and volume of the stock pump. I have been running one in Betty's 914 with L-Jet for 5 years. And you can get it from your FLAPS for about $100.00. |
cwpeden |
Sep 11 2014, 01:36 PM
And the install is as simple as getting rid of the Y and that hose goes back to tank? Check fuel pressure and away we go?
Check fuel pressure procedure? PS thanks |
jim_hoyland |
Sep 11 2014, 05:32 PM
Get that VIN ? Group: Members Posts: 9,278 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
This FI pump has been recommended in past posts:
Fuel Pump napa #N69133. |
messix |
Sep 11 2014, 05:43 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
rock auto has them a hell of a lot less than napa $122.00 http://www.rockauto.com/catalog/moreinfo.p...&cc=1285961
Cap'n Krusty |
Sep 11 2014, 06:21 PM
And the install is as simple as getting rid of the Y and that hose goes back to tank? Check fuel pressure and away we go? Check fuel pressure procedure? PS thanks Not that simple, but close. The new Bosch pump has a 12mm inlet. The correct filter has a 12mm outlet, so you'll need a piece of 12mm hose to close the gap. The filter fits the same adapter hose as the old filter, 9mm to 7mm. 914 356 528 00, which is NLA. Might contact Chris Foley for a replacement part. The Cap'n |
cwpeden |
Sep 11 2014, 06:45 PM
Thanks for all your input guys. I feel more confident that I'm doing the right thing with the right parts.
Dtjaden |
Sep 11 2014, 10:52 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
Amazon has the Airtex pump kit for $71.66.
http://www.amazon.com/Airtex-E8445-Univers...c/dp/B001BFOBXA |
cwpeden |
Sep 12 2014, 01:15 AM
Supported the local dealer and got the Bosch pump. Now all I need is the 12mm outlet filter and I'm off to the races. Any FLAPS part number suggestions?
Literally, I have an autocross on Sunday. |
bandjoey |
Sep 27 2014, 08:49 PM
bandjoey Group: Members Posts: 4,925 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Racer Chris has the reducer but for tomorrow go to the hardware store and get brass nipples screwed together. Take some fuel line with u for proper sizes
EdwardBlume |
Sep 28 2014, 05:50 AM
I installed the new fuel pump in Dads car. So far so good. Not a super easy install though.
First, there is no FI fuel line to connect the larger intake to a larger out put of the fuel filter. I had to use regular fuel or whatever hose. Second, same issue with clamps. I didn't go with any reducer and a different filter. Third, routing the fuel lines in a loop per others experience and pictures makes sense. Buy enough FI fuel line. Fourth, the electric connections are different, but if you look carefully, the stock electric plug is labelled as is the pump. I just made a line that plugs into the stock plug and is screwed on the pump. Different sized nuts on the pump I thought too. Lastly, I used a stock mount bracket and attached it to the firewall using poprivets. The fit isn't perfect so I lined the bracket with neoprene which did the trick. Don't over tighten the pump as you can tweak it. Be prepared to crawl under your car many times. In retrospect, it probably would have been easier to just mount it in the front trunk, which I did to a car years ago with good results. |
cary |
Sep 28 2014, 09:31 AM
Here's the FLAPS part number.
WIX 33274 or NAPA 3274 I went with this one. http://www.rockauto.com/catalog/moreinfo.p...&cc=1263204 |
Lo-Fi Version | Time is now: 11th May 2024 - 01:03 AM |
