> Stripped Gas Tank Threads
cary
post Sep 12 2014, 09:36 PM
Working on replumbing my new fuel pump. So I decided to loosen the nuts that cinch down the fuel tank output pipes. Big one came off without a hitch. The return line, that's another story. The aluminum nut totally stripped out. Steel bung threads are embedded with aluminum.
Has anyone bought the M18 * 1.0 die or thread restorer and cleaned those threads before? Kind of an odd sized thread.
Hate to give up on this tank.
Replies(1 - 19)
walterolin
post Sep 12 2014, 09:46 PM
Had the same problem, didn't want to buy a one time chaser (that's what plumbers call it). I took a dental pick and a wire wheel on my Dremel, and picked at the aluminum for a while. It eventually came clean.
Harpo
post Sep 13 2014, 05:13 AM
My threads were damaged and I cleaned them up with a thread file. Took about 15 minutes but it worked like a charm
David
cary
post Sep 13 2014, 08:50 AM
I'll pick up a new wire wheel on the way to the shop. Then I'll do some picking and see if I can get it.
Called Hall Tool. They have a die, but its $30. And they're not open on the weekends.
Elliot Cannon
post Sep 13 2014, 09:31 AM
Group: Retired Members
If the outside threads are totaled, you can tap threads on the inside and use a different fitting.
Harpo
post Sep 13 2014, 06:52 PM
Depending on the OD of the die the second (return) fitting might to too close to thread the die on. A thread file will fit between the two fittings. One metric file has two ends and four sides per end yielding eight common thread pitches. A whole lot cheaper than 8 dies.
http://www.amazon.com/Allstar-Performance-...d/dp/B003BZLK6O
cary
post Sep 13 2014, 07:55 PM
I have one of those. Won't fit up against the rib.
The wire wheel and the picks did pretty good. The thread file helped in a couple spots. I think if a had a steel nut I could finish it up .............
The aluminum one starts about 2 threads........... so i'm making progress.
cary
post Sep 15 2014, 08:31 AM
Did a little more research. Looks like the M18*1.0 is the only spindle nut that Nissan/Datsun has ever used. Comes in a Dorman kit or in a five pack.
I think I'll still get the die if its narrow enough to fit between the threads and the flange. I still five more cars awaiting restoration..............
cary
post Sep 15 2014, 09:16 PM
Die was a no go. Way too big. We have about .33" of space to work with. It would have needed about about .75" for the die to make a complete turn.
Stopped at my go to hardware store (Winks) to look for a nut. No go. They only went down to M18*1.5.
Ordered the Nissan spindle nuts at the flaps. Should be in first thing in the am.
I'm going make a thread restorer with one of them.
cary
post Sep 16 2014, 09:08 PM
Nuts did the job!
Cut a groove with a triangle file. Worked like charm.
puffinator
post Oct 12 2014, 04:02 PM
QUOTE(cary @ Sep 16 2014, 11:08 PM) *
Nuts did the job!
same problem. would you sell one of your nuts?
Rob
cary
post Oct 12 2014, 06:39 PM
I can do that ..................
Going work in the middle of the night. So I might run out to my shop in the afternoon.
Kansas 914
post Oct 13 2014, 09:38 AM
QUOTE(cary @ Oct 12 2014, 06:39 PM) *
Can you confirm these are 18mm 1.0 threads? I need to do this as well. You might can make some decent money for these prepped with the "V" to cut threads for gas tanks.
I would buy one.
cary
post Oct 13 2014, 06:51 PM
Confirm : 18m * 1.0.
Might give it some consideration. But I'd need to buy a bigger V vile. And something to clean the threads with.
When you start to tidy up the threads The main thing is to use oil cutting oil.
Then only turn about a 1/4 to 1/3rd of a turn. Back it off. Clean it again.
Rinse and repeat.
Eric_Shea
post Oct 14 2014, 07:07 PM
PMB Performance
(IMG:style_emoticons/default/blink.gif)
I knew it would come to this. Andy... time to shut'r down. (IMG:style_emoticons/default/sad.gif)
Kansas 914
post Oct 14 2014, 07:10 PM
QUOTE(Eric_Shea @ Oct 14 2014, 07:07 PM) *
(IMG:style_emoticons/default/lol-2.gif)
r_towle
post Oct 14 2014, 07:25 PM
Custom Member
QUOTE(Eric_Shea @ Oct 14 2014, 09:07 PM) *
Sure, someone talks about selling a nut and Eric comes out of hiding.
Eric_Shea
post Oct 14 2014, 07:33 PM
PMB Performance
Not hiding. "still" at the shop. As you can see, I still have to vaccum. (IMG:style_emoticons/default/sad.gif)
sbsix
post Oct 15 2014, 03:44 PM
only the lead dog enjoys a change in scenery...
Eric, vacuuming and drinking beer do not mix.
Kansas 914
post Oct 16 2014, 07:43 AM
QUOTE(cary @ Oct 13 2014, 06:51 PM) *
Rinse and repeat.
Thanks Cary.
I am having a tough time sourcing these. Where did you get yours? Is there a Dorman number?
- Lo-Fi Version Time is now: 19th April 2026 - 03:41 AM
