Holy crap that's stuck!, How the hell do I get the clutch pin out |
bondo |
Jan 26 2005, 08:32 PM
I'm in the process of rebuilding my pedal cluster.. I got as far as trying to get the pin out of the clutch pedal.
I have tried: pounding pressing with a vice drilling (broke 1 bit, bent another, dulled several) heating with a torch along with all of the above It's rusted in place, and won't budge! Any suggestions? |
ArtechnikA |
Jan 26 2005, 08:44 PM
PB Blaster soak, followed by a pin punch the exact size of the hole, and a 3-lb bronze hammer over a solid backstop (with a slot to allow pin movement).
i hate pedal cluster work... |
bondo |
Jan 26 2005, 08:48 PM
Bwahaha. Air chisel with the pointy attachment got it loose in .5 seconds (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
bondo |
Jan 26 2005, 08:52 PM
That was a short lived victory.. now the pedal is stuck on the shaft.. grr!
Gint |
Jan 26 2005, 09:06 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
LOL! Sorry man, but that was funny. I hope you get it apart.
Rhodes71/914 |
Jan 26 2005, 09:29 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Dude i've been there, struggled for a weekend on and off to get that pin out. Once I did I couldn't get the pedal off, finaly took it down to a mechanic that I know and they had no luck. It was like the pedal just fused to the other part.
I eventually got another cluster from a donar car and it came apart fine. Good luck. BTW I still have the first pedal cluster, you can have it if you want. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
bondo |
Jan 26 2005, 10:16 PM
Woohoo! Victory! (again.. I made sure to get it completely apart before decaring victory this time)
I used LOTS of heat, and twisted with the pedal as hard as I could, eventually it broke loose and made an awful noise. I was afraid it might turn a tiny bit, gall up and be stuck forever.. but with lots of wd40 into the hole and gradual turning, I got it to turn freely. By this time I had hammered on the shaft enough to mushroom out the end.. so I had to pound the pedal further onto the shaft, and file around the end of the shaft. Then with a little twisting it came right off. I was about to give up, but I didn't tell the pedal cluster that (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Thanks for the encouragement! |
skline |
Jan 26 2005, 10:18 PM
Stuff like that I do the easy way, Contact Martin Baker and have him ship you a fresh rebuilt pedal cluster and send him your old one. Doesnt get much easier than that.
(IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Yup, some things I just dont want to mess with. |
lapuwali |
Jan 26 2005, 10:21 PM
A few weekends ago, it took ppickerel and I about an hour at his very well equipped shop to get the friggin' pin out of my pedal cluster. Tried hammering, an actual press, and then finally did it with mill vice.
I also had to use a puller to get the pedal off the shaft. Once I put the pedal back on (and I had to hammer it on, despite a good wire brush job to remove rust), I just used a bolt and nut to hold it, rather than another roll pin. |
bondo |
Jan 26 2005, 10:30 PM
Speaking of pedal clusters, I remember a while back someone said the roll pin that comes with the bronze bushing kit breaks.. and they mentioned a source for the right one. I can't remember the source, or find it in a search. Anyone remember?
Perhaps I'll just do the bolt and nut thing, if I can find the right size bolt without threads on most of it. |
John |
Jan 26 2005, 10:45 PM
I can affirm this. About 15 years ago, I rebuilt a pedal cluster in my silver car. At the time, I was still in school and one day I went out got in my car, pressed on the clutch pedal and the damn pin broke into 3 pcs. The temporary repair was accomplished in the parking lot there at the engineering building. I had to line up the broken parts of the pin and punch them out in place. (MAJOR PITA) I then used a bolt and nut we found in one of the engineering labs to get home. I put the original roll pin back in and it has been there ever since. As I recall, the original roll pin was almost a solid coil, where the one supplied with the pedal bushings had a fairly large void in the center (not as many coils). |
mharrison |
Jan 26 2005, 10:47 PM
Why do I bother???? Group: Members Posts: 633 Joined: 8-September 03 From: Madison, MS Member No.: 1,123 |
I may be lazy, but I dropped mine off at a machine shop. Picked it up the next day for $10 and they gave me a new roll pin for the pedal. Easy $10 for me to spend....
Rhodes71/914 |
Jan 26 2005, 11:34 PM
I got mine from the Porsche dealer, I think it was 80 cents or something like that. |
DJsRepS |
Jan 27 2005, 08:03 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
Idea?? if the void in the aftermarket pin is the prob just fill the void get a snug fitting drill bit and tap it in the center with some lok tite for good measure. Might work huh? Im a rigger from way back. Lack of cash made me that way. Im still using a fishing leader for my gas cable.
ArtechnikA |
Jan 27 2005, 08:29 AM
get some real penetrating oil. PB Blaster, Würth, Mouse Milk, *something* WD-40 is neither. CorrosionBlock has a VERY effective penetrating oil carrier and helps prevent rust & corrosion at the same time ... |
scruz914 |
Jan 27 2005, 09:49 AM
Senior Member Group: Members Posts: 815 Joined: 26-February 04 From: Santa Cruz, CA Member No.: 1,724 |
Always a good idea to keep a cool head and not to let your car parts know your frustrations! Some of those guys will be a pain just to see how quickly you will give up. |
double-a |
Jan 27 2005, 12:21 PM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
you know, i've heard over and over how hard this is, but my pin just came out. i locked the pedal arm in the vise, grabbed a small hex bit and used that plus a hammer to punch the pin through. it was tight but came out in about 20 seconds. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
~a |
bondo |
Jan 28 2005, 09:04 PM
It's done!
(it was such a pain I just had to share) Attached image(s) |
bondo |
While I'm at it: (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Rhodes71/914 |
Jan 28 2005, 11:22 PM
Looks good.
It was so nice when I got my rebuilt cluster in and the brake pedal actually came back after being pressed down. |
Lo-Fi Version | Time is now: 15th May 2024 - 02:51 AM |
