dodge intrepid V6 conversion?? |
heck914 |
Jan 26 2005, 11:53 PM
Newbie Group: Members Posts: 16 Joined: 10-December 04 From: southern, CT Member No.: 3,256 |
Anyone ever seen / heard of / or have pictures of 914 with a Dodge Intrepid V6 drivetrain?? after looking closely at one , and taking a few measurements, i was thinking it could be a decent (and cheap)donor for a 914. the complete engine and auto transaxle. I know having an auto trans would be a little "wussy" but it would be different. 1 hurdle (beside the electrical lol)would be geting some sort of custom half shaft to mate the transaxle to the hub/swingarm.
scotty914 |
Jan 26 2005, 11:57 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
go suby and get an auto tranny for a fwd only. bolt up with just a little fabing, tranny designed for the motor etc etc. 165 stock hp on the suby 2.5 l. and it looks like it belongs there.
quick ? is the dodge a transverse motor |
skline |
Jan 26 2005, 11:58 PM
I think it could be doable but why? The Intrepid is a POS in the dodge, why would you want to put it in a 914? The idea is reliability. Chrysler lost their reliability back in the mid 70's. I actually thought about a conversion using an Audi 5000 automatic transmission. The question on the hub mating was what held me back from trying it. I think it would be cool to have an automatic in a 914. It would be great in traffic.
scotty914 |
Jan 27 2005, 12:00 AM
when i do scotts tool wench ( teri )'s car it will be a suby engine and tranny
althought the audi tranny looks very nice for swaping |
morph |
Jan 27 2005, 12:16 AM
quality parts builder Group: Members Posts: 1,828 Joined: 25-November 03 From: oregon coast Member No.: 1,389 Region Association: Pacific Northwest |
i totally agree with skline i owned a 97 dodge intrepid it was a great car but had big problems.the only reason it lasted 175 thou miles was because i was gear head.
did you know the heads leak from the factory? (3.3-3.5L) i can go on and on about what the techs and the local dodge dealership told me about the 2.7/3.3/3.5 the 3.5 the water pump inside the block.and all of them have no provision on the block for a dizzy,the motor is totally computer controlled.so you need the complete compter system to go with it.all of it including systems you prob wouldnt need,just to make it work right.but on a plus side the motor was alot more relable after 01. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) james |
nebreitling |
Jan 27 2005, 12:28 AM
xsboost90 |
Jan 27 2005, 05:21 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
when i was a mechanic i did nothing but replace auto transmissions in intrepids all day long, and mini vans. It may have had something to do w/ the lousy radiators w/ tran, oil and antifreeze in one intermingling, but still not the best. Now a boxster drive train....although they had problems too so get the "s".
TheCabinetmaker |
Jan 27 2005, 06:53 AM
My daughter, against my advice, traded her Gran Prix on an Interpid. It was a big mistake. It's a total POS! Tranni has been rebuilt twice in 6 years. Requires constant bleeding of the cooling system. They even put a bleeder valve on the thermostat housing as an after thought. DON'T EVEN THINK ABOUT IT!!!!!!
heck914 |
Jan 27 2005, 08:03 AM
I have also know about some tranny problems too. But the tranny wouldnt work nearly as hard pushing a car around that weighs almost 1000 pounds less.
cooling issues can be dealt with as you would need probably 2 bleed off points anyway. (front of car and engine) I agree about the electrical. There would be lots of circuits that wouldnt get used. Just thought it could be a relatively cheap different project. |
Mueller |
Jan 27 2005, 09:56 AM
It's been done...sorta, not sure if he has it running yet or not...some guy back East...he built a subframe to attach the new motor/tranny combo to.
we had an intrepide for a few years...it was a fun car to drive for it's size, but we traded it in at 80k miles due to too many little problems....none of which would be an issue in a 914... there will be just about 0 support for you unless you can hunt down the guy that did his conversion...about the only thing anyone here can give you known good advice would be the cooling system which can be run just like all the V8 Chevy conversions.... |
AZ914 |
Jan 27 2005, 11:23 AM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Hey, doesn't the Intrepid have a tiptronic?
ninefourteener |
Jan 27 2005, 01:46 PM
Perfectly Normal Guy :) Group: Members Posts: 1,216 Joined: 3-June 03 From: St. Louis, MO Member No.: 779 |
I don't see how this is possible. The Dodge Intrepid has the most peculiar engine/tranny setup I've seen in a long time.
The engine sits in the car like a rear wheel drive car..... the plugs are on the sides, NOT in the front and back......... Yet the car is Front wheel drive. Which means the tranny in an Intrepid is kinda at a 90 degree angle.... or something.. I dunno. Maybe thats why Dodge had a shitload of recalls on the transmissions in those cars. How could you use a 90 degree angle tranny? Whether you're using a front wheel drive subaru engine, or a rear wheel drive buick V6 or Checy V8..... the transmission has to be a "conventional" transmission. The transmission is centered on a 914, so with an Intrepid tranny, the engine itself would either be way on the right, or way on the left side of the car (depending on engine rotation) and throw the balance off...... so much for great handling. Perhaps you could use an Intrepid engine..... but I don't see how you could use the tranny. But then the question is: Why would you want to?? |
Mueller |
Jan 27 2005, 01:54 PM
huh?? I don't know what you have been smoking? (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) looks just like the 914 engine/tranny combo in how it's setup here is the engine: Attached image(s) |
Mueller |
Jan 27 2005, 01:56 PM
and here is the transmission...you can see where the tranny mates to the engine....you can also see the drive axles are 90° from the centerline of the engine...just like the 914 motor/tranny combo....
Mueller |
Jan 27 2005, 01:59 PM
yes, there is a drive for the axle on the other side of the transmission....
looks like a tall engine, anything can be made to fit, but it might not be as cheap as you would like due to custom parts that'll be required... |
banderson |
Jan 27 2005, 02:11 PM
Member Group: Members Posts: 88 Joined: 22-August 03 From: Massachusetts Member No.: 1,064 |
I heard that the '99 Acura TL had a longitudal engine layout with a Tip tranny. Probably similar to above. Never seen one but thought about looking into it for ha-ha's.
I would take an Acura V6 over a dodge. |
Mueller |
Jan 27 2005, 02:20 PM
same here...the Honda and Acura V6's are dirt cheap as well, there is no real demand for them, all the hot-rod Honda guys stick with the 4's so the V6's just collect dust..... |
aircooledboy |
Jan 27 2005, 02:58 PM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
To lead the hijack further astray: (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
I was at my buddy Stef's shop today, and he had a 6 out of a Lexus on the engine stand and I couldn't help but think: "damn, that's a little block, the sucker oughta fit nicely in a 914 (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) " (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
scotty914 |
Jan 27 2005, 06:00 PM
mike i thought you learned your lesson with v6 engines, suby engines are stolen designs from porsche and vw any way and fit perfectly and i think i could do another one in 40 hrs in a shop setting, if someone else built the engine bar, currently i have 4 hours in modifing the engine ( flipping the intake and stuff ) 12 hours spread out over 2 weeks on the harness. the radiator setup should take 4 hours complete, total cost about 1200 plus engine. |
Mueller |
Jan 27 2005, 06:29 PM
I learned the hard way..the darn VR6 engine is still sitting in my garage (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) no plans in the near future for a swap (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Lo-Fi Version | Time is now: 3rd May 2024 - 03:00 AM |
